nice!
is that mine? (DHL has it since tuesday….)
The r90ts doesnt look that good now. It simply has more lumens over the r90c, the same throw and by the looks alot less runtime.
It reads turbo 60s which must be step down time as even high runtime is short and they have 8 cells. Really dont think its worth it if without more throw.1700m isnt much, the blf gt4 sounds like it will beat it by far with good sustained lumens.
Compared with Acebeam X70, MS18 has twice as much lumens output, here’re some pics from my friend Dabo.
ms18:
x70:
temperature test with ms18 when it in steady state:
It depends on how you look at the specs. The R90C says it does 20,000 lumen (really closer to 16k-17k) for 3.5 minutes.
The R90TS rating says it can do 15,000 lumen for 80 minutes. This is thanks to the better cooling.
So at this lumen level the R90TS is superior to the older R90C.
Thanks for posting the graphs Pearldriver. It’s hard to imagine the MS18 is more than twice as bright as the X70. That would mean it is making over 100k peak lumens. However, it seems like the sustained load is about 14k lumens. Was hoping for 20k lumens sustained.
Definitely impressive…
It looks like the sustained on the MS18 roughly matches the sustained on the X70. Sustained on the MS18 was 647 and sustained on the X70 was halfway between 400 and 800, leaning a little closer to the 800 side in the beginning. While it’s not 20,000, I’m hoping it means the sustained is closer to 18,000 like the X70 is advertised.
That doesn’t appear to be measuring lumens. It seems to be measuring lux which can vary based on the beam angle from the reflector (wide, narrow, etc…)
We need more info on what is measured and how the measurements were done. Ideally you need a large integrating sphere to take the beam angles out of the equation.
Got some beam shots??
beam shots between 90ts and x65.
Did Dabo’s MS18 stop working completely from a fall?
What’s the status of these lights? Have they made it to the dealers yet?
they will arrive to the shops this week
mailcall ;)
Just gorgeous….
Cant wait for your video
Same! Hopefully by tomorrow?
lets see
lots of rain here predicted for the week - i might split Beamshots on the field and hands on into two sessions...
charged them and made a few pics:
Beautiful beast
