That’s definitely clearer! :+1:
Or “SSD drive” which annoys me quite a lot.
P.S. Don’t shout at your JBOD’s! In case you don’t get the reference.
Having once worked in a data center doing hardware stress testing, I’m suddenly disappointed that I never tried this.
^ That’s better, CRX. Also I’m glad you removed the instruction text from the bottom. I think that should be separate, as the diagram is meant for quick reference (also the very long image becomes unwieldy to deal with).
Yeah, getting clearera the more I sober up
The quest for FW3A ‘Cheat Sheet’ perfection is closing in on…… P.E.R.F.E.C.T.I.O.N.!!
Together, we can do it
Amen!! …
+1
@ wle
Is that a Glow Gasket thing from Neal??
What color?
what are u using to make it glow?
I am using a piece of gitd tape. All around the inner wall of the head.
that was what i did, just cut a ribbon from glow in the dark tape, about 3-4mm wide, kind of hard to get it straight inside the head, but you can do it with tweezers
it’s SUPER bright, right next to the leds, it is probably making 2-5 lumens for a few sec after the light goes out
this is that same GITD tape from aliexpress i got about 5 months ago
still looking for things to do with it, it is still impressive
and i have a ring around the body of it too, but that doesn;t get charged by the LEDs so it is not as impressive or bright
wle
it is just basic green glow in the dark tape from aliexpress
you can get 1/2 x about 20 feet for about $3
i cut the ribbon and stuck it inside the head
green is the brightest GITD color
it isn;t as blue as my pic shows, that is white balance from the camera being fooled i assume
wle
Thanks wle… it looks good!
yup
prob 5 lumens
what is a glow disc though?
wle
