So, guys and gals, now that I’ve shipped all orders, and reshipped some orders that were taking too long to ship, I’m ready for the 3rd gen spring groupbuy.
Here are the springs specs.
Large BeCu spring(Rev 3.0):
Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 6,25mm
Spring base diameter: 9mm
Spring thickness: 1,0mm
Spring height: 12mm
Total number of coils: 5
Plating: Copper(25 um)+ silver
Small BeCu spring(Rev 3.0):
Spring upper diameter: 4,25mm
Spring base diameter: 5,75mm
Spring thickness: 0,8mm
Spring height: 10,5mm
Plating: Copper(20um) + silver
Because of the thick copper plating to give a large boost in conductivity, the spring is again quite a bit more expensive than even the 2nd gen silver plated version.
Now, we are at 0,46$US/spring.
Express your interest below.
Will make a 3rd thread for it soon enough, along with some sweet sweet FD2 SST-20s. Will also be making budget phosphor bronze springs, probably at 0,15-0,20$US/spring along with some new additions.
Hi BlueSwordM,
I would like to get:
10x large and 10x small rev.2 springs
2x sst-20 4000k FD2 LED
If you don’t mind I would like to wait to be all sent in the same shipment.
Thank you.
EDIT: I agree with paying you the springs in advance
Could you maybe tell the spring company to produce the springs with the upper end of the spring wire bent to the inside, like on the Rev 1 nickel plated spring? I suspect that the wire ending resting on the outer margin of the silver plated springs scratched my batteries more because it is quite sharp.
No problem guys. Just wanted to see if the springs were easier to work with, but wasn’t the case.
Also, for the SST-20 FD2 LEDs, we have to go quick. They might not be here as long as I want, so I’ll probably send payments only for the LEDs first, and ship to those with only LEDs first.
