rubber button that is more “recessed” is now slightly unresponsive… clicks dont register as well as it used to. sometimes when you double click for turbo, the light wont go to turbo. you have to do it again. the clicks are not as “loud” as it used to also… avoid the ones with recessed rubber switch if possible…
I just received my new Anduril flashed, tint mixed D4 from Hank. Aside from being downright awesome, I just noticed that my driver has flashing vias. Not sure if ive ever heard or seen these in the wild yet.
That is fantastic news, and I think I will have to get one. The D4 is the most overpowered unmodded light I’ve encountered, so it’s sort of a worst-case scenario for thermal regulation. The ability to reflash it without taking anything apart would be incredibly helpful for thermal testing.
I still find this weird considering it even has vias to flash. Maybe it was just too similar to RampingOSv2 for him to see a reason to do it. Maybe shoot him back an email and ask him if he could do it for like $10?
Id offer to do it, but I killed one by flashing corrupted fuse bits and now that I have 2 working Anduril XP-L HI D4S with calibrated voltage I wont touch them. Im apparently alone in this feat though as TK has never had an issue that im aware of.
I read on reddit that the D4 should be soon available in the same sand color of the D18! Is this true? I wish he also add a knurling on the tube like the titanium version.
Aye. I would love Green or Titanium, but sadly I missed my chance for either of those options.
As the new D4 has flashing pads on the driver, will there be an adapter available, or will I have to get creative with some modelling clay and bare wires? After trying the improved 6/02 version of Anduril, I simply must have it on my flashlight.
It looks like you got one with a 2019-05-21 build, but I think the D4 should mainly ship with a 2019-06-05 version instead.
Muggle mode has been removed at Hank’s request. It seems to cause too much confusion. I’m kind of happy to have it taken out, TBH.
I’m hoping Hank or someone will make the pogo pin adapters commercially available, but I don’t know what will happen.
It’ll definitely be required for the Anduril version of the D4 though. It seems those are using a new tiny1634 driver, so the pogo pin adapter is the only way to flash it. A SOIC8 clip won’t work.
The RampingIOS version is still tiny85 though. That code hasn’t been updated to run on tiny1634. So if anyone wants to make sure they get tiny85, order the RampingIOS version.
