I am so excited to see this! Clemence work is always top quality! Hope they will be in copper instead of brass…
Nice work Clemence .
I’ll take a copper pill with no wire holes drilled if you ever wanna sell one.
That’s a lot of work replicating those pills. Nice job
Excellent work, Clemence! Great to see all this, keeping the RRT-01 as relevant as can be.
Thanks for all those supportive comments above
In my opinion, pure copper (I used 99,95% copper) is not the best material for RRT01 for below reasons:
- too soft, dent easily
- copper thread tend to be weaker than 2024 aluminum or any brass thread.
- hard to machine
- expensive
- too heavy for EDC. Stock brass pill weights 17,08gr, modified brass (high copper) 23,26gr, copper (99,95%) 23,92gr
- also, aesthetically non visible
For RRT01, modified pill made from 2024 aluminum weights approximately only 7,42gr. More than half stock pill with thicker LED base and more material overall. Although copper has roughly triple the thermal conductivity of stock brass pill, with aluminum its already doubled. What do you guys think?
[Clemence]
I say go for alu. Maybe this light will be ok for edcing afterall with the weight reduction.
I had already been thinking why Jetbeam chose brass for the pill. One reason could be that the pill is the guidance for the ball bearing, the metals on both sides of the ball, SS (the ring) and brass (the pill) are slippery and wear resistant, while aluminium (and copper) is non-slipping and wears easy.
The question is if this is relevant for a simple low-tolerance magnetic ring construction or would greased aluminium work just as well, even over time ?
For all other reasons, I fully vote for aluminium, the best flashlight material in the world.
Personally, I don’t mind the weight because the light is so small anyways. I vote copper.
You have a point with the wear Djozz, but soft copper is certainly not a good option than.
Maybe an alu pill and a brass ring for the ball slot.
Or maybe a more wear proof alu like 6082 or something.
Although I think it would take quite some time to wear out soft alu.
Brass = the golden standard for metal machining. Any hard/easy to machine standards always compared to brass.
Brass has the best dry lubricity for metal to metal contact, superior galling resistant. Even against it own
Aluminum can be anodized or greased for better wear resistance. But seriously, a true 20xx aluminum is very strong. I don’t think all those manufacturers with “aerospace aluminum material” really use 20xx or 70xx aluminum. These aero grade aluminum can also heat treated for even better strength. I will check local supply for used 7068 scraps. IMO, 7068 Al is the ultimate flashlight material.
[Clemence]
I think Alu is fine
I have a box full of damaged Vertex dirt bike cast racing pistons, they have very high silicone content (some as high as 20% for 2000 model). The Si content is so high they are brittle yet very hard, perfect for high revving low torque 2 strokes. Tried to cast them but unusable other than for their specific purpose. Tapping a thread on it was useless.
I heard Oveready use superior ultra strong aluminum billet alloy for their lights. It’s doesn’t really requires anodization.
[Clemence]
ALU 7068 voted.
I say aluminum. The light is too head heavy. I have had other lights with ball bearing and magnetic ring in aluminum without issue.
I also well grease all my ring lights.
I like copper mcpcb and aluminum pills. Uses the superior thermal properties of copper where its most important. Moves the heat quickly to the aluminum and keeps the flashlight nice and light.
I predict synthetic diamond is the future for extreme high power. DCPCB has been used in military and space equipment, mainly for laser and CPU. The cost of synthetic diamond keeps dropping as the technology advanced.
This far, the nearest concept to DCPCB at mass production rate is AlN direct metallisation copper board.
Soon there will be copper based nano ceramic insulated MCPCB very similar to my previous board. The factory introduced it to me but the whooping $10.000 commitment cost held me back from even read the spec any further.
[Clemence]
More pics added in OP
testing Clemence!
Apart from the nice graphs, I think it is nice to know that the 18350 Vapcell has a functional thermal fuse.
Thanks for the tests Clemence! Very useful.
Are you planning to change the driver too to add LVP? That seems like a tough job.
