Jetbeam RRT01 is one nice flashlight with very intuitive UI. The concept is great, the look is OK (most, including me prefer older styling), butt…as there’s always reasons for BLF people to mod anything. For RRT01 it’s a big BUTT:
Dangerous no LVP, thermal limiter nor output step down.
Melted wrapper, tripped internal protection, bulged bottom
Hole drilled to relieve the safety switch. Usable but no protection anymore. I resealed the hole with two components potting silicone.
Stock pill machining is bad, very loose rattling tolerance (for the rotary ring). Uneven, eccentric milling, too many unused holes (recycled leftover surplus pill for various MCPCB model). I over saturated the picture to show the machining marks better.
In my opinion, this one is the worst from engineering POV practice. To accommodate new MCPCB screw hole location, Jetbeam drilled and tapped new pair halfway over existing holes. :person_facepalming:
Stock copper MCPCB isn’t any better.
Definitely rough and not flat. This MCPCB was punched with dies instead of routed. Note how the rounded base edges eats up the precious mating surface area. A solder blob made things worse preventing flat contact between the pill and the MCPCB. Mind the low quality phone picture
Recycled MCPCB designed for Eye10 dated back to 2012 February 11th. The time when Sunwayman V11R was a big hit.
For me, stock RRT01 is potentially dangerous and definitely has to be modified to keep up with current flashlight standards. It has lots of potential and also lots of works.
I know I’m very slow but at least, this is what I made so far…
Pic taken fresh from the machine, there are still flares and chips
all three in the left are modified brass and copper version. Note extra O-ring groove for a complete waterproofnes. Also tighter shaft to rotary knob clearance for smooth rotation
Left: modified, Right: stock OEM
UPDATE 190724: Aluminum pill progress
Optic update and beamshots:
[Clemence]
