The SST-20 would be the best candidate if it were available dedomed from the start, as it is currently the only emitter(beside the E21A and Optilosis) to have R9080+ levels of color rendition.
If it was available in 5000k 95CRI variant, I think it would change a lot of stuff, especially available in good tint bins.
Thanks contractcr, to my eyes those two look identical. Very nice comparison, I have also seen TIR’s that shift to some completely odd ball tint. That’s pretty amazing how different TIR’s can make such a difference. It also amazes me how much the LH351D 5k changes to such a nice tint when shaved.
In jon_slider’s saturation pic of the “Mostly shaved LH351D, SMO reflector” it looks like it has a bit of green. I feel the closer its shaved also makes a difference in tint, I’m no expert but I see no green from shaving close with my samples in a SMO reflector.
Thanks for all the pics gentlemen, really educational.
I do feel that if more people tried the shaved LH351D it would become even more popular.
If I ever spend the time to figure out how to take tint comparison without looking completely different than what I see, I’ll post those up.
Djozz test with a shaved LH351C if anyone is interested. GB 351D closed. - #713 by djozz
I learned a new word today .
So jon_slider when you are saturating the pics what exactly is that doing because I see nothing in person like in that pic above.
His pic looks close to what I see, the 219b looks pure white and the 351D looks slightly warmer both with a slight rosy tint. Just trying to figure out what the saturation pic does when I see nothing like that here.
With all the hype over the 219B sw45k it’s still way too cool for me personally. If there was an emitter that rosy at 3000-4000K I’d be all over it, but for now SST-20 and shaved LH351D do it for me for TIR and reflector lights respectively.
So in my picture all those tints are within probably ~600K CCT of each other (3975K~4600K -ISH)
The “mostly shaved” LH351D only looks green in comparison to the much lower DUV ones. If I only use that light by itself I cant notice any green at all. Also, the 219B SMO does look rosy cause it’s driven harder in single LED. The FW3A would have to be cranked up before it gets the “too rosy” (IMO) look.
should be slight above BBL (but >= 4500K)
RIGHT on BBL (like nearly 0.0 duv, and right around 3975-4000K)
I’m still trying to figure out what a saturated pic shows, I have done some reading and I’m still not sure what that does.
From what I have read it depends a lot on what color temperature the original image was shot at, then there’s a whole can of worms you can open up to adjust color by saturation. The digital camera only knows the value of a color of RGB and any one has a value between 0 to 255 that all three values make up a certain color and how the camera sets the value of the image determines alot on what saturation can do to the colors. I’m not a photographer though and this stuff is way over my head.
I think saturation just shows whatever is there, more intensely
it does not change the tint, and it does not change the color temperature
its just a way to turn up the colors, to make them more obvious, and exaggerated, imo
I agree it is very difficult to get a photo to look like what our eyes see, especially photos without a consistent white balance reference… I propose daylight white as the best reference, 5600k
what our eyes see, changes at night, compared to during the day, because of our brain using different white balance references
that is why I try to always include a cool white reference in my photos, and why I include a familiar Nichia…
I look forward to getting some first hand experience with the LH351, once I receive the light generously offered by contactcr. So far, I do see some pink in some of the pics posted…
I respect those of you with LH351 experience are getting more lumens than with a 219b, and that you seem happy with the CRI and tint.
Instead of saturating images to show tint, I find it’s more revealing to normalize the brightness of each individual pixel. This basically eliminates differences in brightness, showing only the pure tint. The algorithm is really simple… just scale the brightness up until one of its color channels hits 100%. The color is otherwise unchanged.
Also, sometimes I blur the image first before putting it through the disco machine, to blend nearby pixels and reduce the impact of jpeg artifacts.
For example, given this beam shot someone posted on reddit… (I forget who; it seems to be deleted now)
Here’s what the disco machine spits out:
I think it’s a fine example of the “Cree rainbow” effect.
I like how saturation makes it totally obvious what direction the tint deviates from white… but I don’t like how it exaggerates the amount of deviation. It’s misleading, making things look worse than they really are. I can tell which direction it goes in, but not how much.
So I usually stick to a method which leaves the tint unchanged but normalizes the brightness to compensate for variance in different parts of the beam. A slightly off-white tint will still look only slightly off-white, instead of being exaggerated all the way to a saturated neon color.
