“All tools,” said Nessus. He pointed. “These are flashlight-lasers with variable beams. At night one can see great distances with these, for one can narrow the beam indefinitely by turning this ring. Indeed, one must be careful not to burn holes in nearby objects or persons, for the beam can be made perfectly parallel and extremely intense.”
Okay, hank, you want science fiction, I can give you science fiction.
What say you of a torch that illuminates things and immediately scans and identifies the objects or beings it is illuminating and sending the info to display in that trusty personal digital device you’re bound to have (PDA, tablet, smartphone, datacube, whatever you want to call it)? All that with just the emitter, no camera needed.
Speaking of which, it makes me wonder what you’d get if you put a modern LED light inside SCP-914 and set it to Fine or Very Fine.
I know its a lack luster flashlight but the fact it was so bad made the game better, the flashlight in Metro was a great tension builder.
You had to keep whipping out a home made charging apparatus to make it work. And we complain about turbo only lasting 30 seconds, image your flashlight going off whilst fighting a mutant in the future in a Russian sewer.
I think the beam looks like a dusty Convoy C8 on an el-cheapo ultra mega fire cell
Any infrared viewer still needs an illuminator; it would be nice to have corneas with “light intensification”, then the light of the moon, of the sun stars, without illuminator is enough.
The tapetum lucidum is a biologic reflector system that is a common feature in the eyes of vertebrates. It normally functions to provide the light-sensitive retinal cells with a second opportunity for photon-photoreceptor stimulation, thereby enhancing visual sensitivity at low light levels…
The tapetum lucidum is a reflective surface that causes the eyes of animals to look like they are glowing in the dark. Many species of nocturnal animals have this layer in their eyes.
I’d like to have the flashlight laser from Larry Niven’s Ringworld books. Can be used as a variable intensity wide beam flashlight or focused down to needle diameter to burn through rock, metal, etc
They didn’t mention the power supply but I think it s a tiny deuterium fusion reactor
The variable sword is wicked too. Looks like a jump rope handle and pressing the button causes it to spoil out invisibly thin wire that passes through a “stasis field” to make it indestructible
I like SCI-FI A liquid nitrogen cooled double walled light where the tail switch carries the motor and threw magnetic power circulates the fluid using a propeller, like in fish tank filters, It would have a combination of LED’s from the four centered SBT90.2’s behind a 60mm TIR lens. The outer part of the TIR lens would be a combination of other emitters functioning in a triangle pattern so you could have 5 sets of three emitters like, three UV, three 3000K three 5000K three Green and Three red. All running separately in there own groups for different needs so the emitter choices could be endless. It would be powered by two Tesla 54980 cells, can’t wait to here more on these!, With an led readout display of temperature, lumens, time, volts, all the goodies! It would also be USB and magnetically chargeable along with a portable folding solar panel for in field charging. Lets not forget to make it a power bank as well. Just what I could think of off the top of my head I have high hopes for flashlight technology in the next 10 years
Yep kind of like that. They discover a zero entropy technology called “stasis fields” that makes anything within the field indestructible and no time passes. So they make a handle with a tiny stasis field at one end through which the invisibly thin wire passes. Usually people extend it to about 1 meter length and it has a little red ball on the end of the wire so can see where it is (:
Not sci-fi, but was just browsing through “Reaptown”, and it was refreshing to see this chick with a real flashlight, decent coverage and brightness, and not just some dinky AA Minimag or something.
In the Niven books, most species use some variety of fusion power. Usually deuterium, due to the scarcity of Tritium and the difficulty of fusing Hydrogen-1 a.k.a. Protium
However, in some books (and the Man Kzin novels), there are races that have total conversion technology. I remember one story where someone came up with a device to suppress the spin on the neutron which caused it to be converted directly to photons
What about endothermic lights? That absorb heat from the environment around them and turn it into light? Because I sure as heck could use one of those right now.
