I thought the SC31 was the bargain of a lifetime at the 17bux it was going for. Perfect light for the muggle with everything you’d need (eg, charging).
My only grex would be the “breathing” light (which I just kept turned off anyway, so no big deal), as I prefer the Nitecore style “beacon” (short blink every few seconds).
Always on Low.
However there is something unexpected: Eco can only be reached after going through Low-Medium-High. There is no shortcut to Eco from Off :person_facepalming:
Ah that’s a shame, not even if you press and hold the button from off? Really needs a shortcut to Eco imo. The only thing I don’t like about my SP10B is that it effectively doesn’t have a Low, it just goes straight from Moon-Medium.
Edit: I guess the work around would be to always run it with 14500 and switch to Eco before turning off: “It memorizes the last brightness level used in the general modes when it is powered by 14500 battery”. This would make the other modes too bright for me though.
The WK30 has aroused quite some interest both here and on TLF. I hope I can convince Mark to distribute this light not only to the US market but worldwide.
I will get in touch with him and see if there's a chance for a global groupbuy (BLF and TLF at least). :-)
I wanted to put a magnet there but I can’t figure out how to take out the spring from the tailcap. Doesn’t seem it’s screwed into the cap like the other flashlights.
You might consider making an array around the spring and glue them down. Place within the inner diameter of the body tube. Since the light has enough space, 5 mm wiggle room, for a 21700, you may stick to xx650 batteries.
