The There Are No Stupid Questions Thread
No, it improves light extraction.
That is: die emits some light, it enters silicone dome or a flat piece of silicone. Then travels across the silicone and hits silicone-air edge. At this edge some of the light passes but some reflects back.
With dome, light hits the silicone-air edge more perpendicularly. This reduces reflections and improves light yield.
Typically domed emitters give 10-20% higher light output.
But they also give less throw, much less.
See this to get a full explanation:
The dome basically acts as a lens that enlarges the size of the LED’s phosphor relative to the reflector.
How easy removing the dome is depends on the particular LED. Some can be sliced easily, some should have the dome removed with a chemical solvent as physical cutting will damage it.
Do many people here really examine those highly technical graphs (like CCT comparisons over runtime) that the most technical reviewers put in their content? I am impressed with the scientific and mathematical minds who endeavor to produce all of that work, but… I often wonder if it makes sense to only a very select few of BLF members. It often feels like such highly technical reviews require far more effort to produce than the very light given is even worth.
I do appreciate some graphs, like runtime on various cells, but in the end the aggregate performance numbers are my main interest (total runtime on each brightness level).
Data are always good.
If people are willing to make those graphs, I’m always happy to have them. I’m an engineer and usually know how to interpret the graphs. If not, I can always ask :slight_smile:
Bear in mind that those graphs also supply the information that the “select few” can use to answer questions accurately and give good advice to the rest of us.
A lot of that info is relevant to choosing what emitters/drivers/optics/etc. work best in combination. For example seeing that the Nichia 219C has a low forward voltage means you do NOT want to put it in a single-emitter FET light. Some of the other info shows that new emitters render old ones obsolete (or that they don’t) based on things like color quality too.
Furthermore it shows how LED tech is advancing and just what kind of improvements/disadvantages things like the jump from the design of the XHP50/70 to the .2 versions offer.
I have both the Astrolux ft03 versions. (sst40 & xhp50.2) I’m looking to dedome one of them. Which would be the best to dedome?
Keep the sst 40 dome on the ft03 I cannot speak for the 50.2
The XHP50.2 will be an easier dedome job since it’s a flip chip (no bond wires in top), on the SST-40 you’ll have to be cautions of the 2 bond wires plus the ESD protection diode.
Also, if the sst-40 in your FT03 is anything other than cool white it’ll be impossible to replace if you mess it up.
Wouldn’t dedoming the sst-40 gain more throw than the xhp50.2?
Well yes, but like I tried to explain its a notoriously hard LED to dedome and the supply of non CW SST-40s is literally non existent. If you mess it up on your first try you can not get another.
The dome may also serve as a chemical seal to protect the phosphor from eventual contamination by volatiles coming from the soldering and heat transfer goop.
If you remove the domes you can buy a paint-on liquid sealer and apply that. I used to have a link for that stuff but can’t find it now.
There’s a lot written about failure modes for LEDs, problems that will start to appear over time (only after 10,000 hours, of course, trust the sellers on that).
https://www.tandfonline.com/doi/full/10.1080/09506608.2019.1565716
That makes perfect sense. What about a partial dedome? Not going too low as to harm the bond wires, yet still leaving a protective layer to protect the led?
The word “dedome” implies removing the whole thing. With certain leds you can just slice off the top leaving a thin layer. This has almost the same effect. Candela increases a lot. Some leds are harder to slice than others and the results can vary. With the 50.2 folks recommend a “slice and dice”. You slice off the top and then slice off the sides. This is supposed to help remove some of the yellow corona and or spill, but when I tried the spill light stayed yellow.
It’s always best to have a spare led in case you don’t like the results or accidentally damage it.
Thank you for the info!
That’s good to know. I guess that’s why the Nichia 219C has been popular for use in triple and quad emitter designs?
Okay, here’s my No Stupid Question:
Is this a 7135 * 5 driver?
The missus must prepare the salaries of around 30 employees on a monthly basis (many still handed out as some staff don’t have / want bank accounts) and in addition sometimes have to check other papers of value for authenticity. That’s why she wanted a portable UV flashlight. Something better than the non-portable old and dim unit she now uses. The choice fell on a Convoy S2 Gray 7135 * 5 Driver 365nm Purple UV Flashlight. A seller was easily found on the internet, and the lamp was ordered.
Good price, a series of clear photos of the product and the following specifications were mentioned:
Features (shown in the main photo):
- Gray S2 LG UV 365nm
- LEUVA33W70RL00 LG UV 365nm LED
- 7135 * 5 1750 mA single mode
- ZWB2 filter, and a bit more down the page:
- High quality aluminum alloy.
- LG UV365nm LED 5W lamp beads are used.
- The built-in drive is 7135x5 single file.
  • Life waterproof design.
Out of curiosity, and after playing a little while with the light (yes, we also got ourselves a pair or 3M safety glasses) I opened it and saw that the driver board looked different from the pictures of the seller. I know there is an (old/different?) version with the specs 7135 * 3 but I can’t find a good image of the 7135 * 3, or the 7135 * 5, let alone of the differences.
I know that the current stabilizers (I think that’s the right name but correct me if it isn’t) can/will be on both sides of the board, but because I didn’t take the light further apart I only see the two stanilisers on the spring side. As shown on the second photo both our 2 ‘black boxes’ are printed / engraved? with the text 7135 35P. I can find all different 35 codes, but not 35P. The seller’s photo (photo 1) does not show any visible markings (might be the lighting).
There is another small difference I noticed. On the light she has the name convoy is printed, whereas the seller’s photo shows the text convoy*2* (photo 3).
So my question is, can someone tell me if this is the 7135 * 5 1750 mAh version, or can it be that this is an older 7135 * 3 1050 mAh version? I’m just curious and if it’s not what she ordered I might leave a negative review on the seller’s webpage, to warn others. The missus doesn’t care too much, she’s running around and showing everyone the ‘miracles’ of this little flashlight (and looking silly with those glasses on but I don’t dare telling her afraid she will no longer wear them). I’m sure that by now it has some minor scratches or dents, so it stays, gets used, and abused.
Thank you all! :slight_smile:
The seller’s photo:
The light that came:
Inside the head:
The 7135 is a current regulator. It allows 0.350 amps to flow (some do 0.380, but are not as common). Those drivers typically have room for 8 of these chips. It’s possible the other side has 4 chips making it a 6 chip driver, not 5. We don’t know for sure, though.
Another way to test is to measure the current draw through the battery. A 5x7135 driver should draw 1.75A. A 6x7135 driver should draw 2.1A.
Here are both sides of the same driver with 8 chips attached.
Who doesn’t have direct deposit these days? My employer actually requires it. From my understanding, it’s expensive for an employer to actually cut a check.
You sound like the tax man looking for people getting paid in cash.
Haha not at all. I’m just saying, there are actually companies that require direct deposit.
