The sst40 is a 3V LED, also the driver is only suited for 4,2V
Sky Lumen has a modded version of the L2 with SST-40 on 2x26650 for 280kcd. If I understand this correctly, it’s a buck driver (DriverVN4), based on the spec of the SST-40 you provided?
I’m not familiar with Vinh his drivers, Simon (Convoys owner) does not support 2x 26650 for the SST40 (at least not the L21a)
@Simon. Looking at the XHP35 driver, can I just confirm that its 2.3A at the output and single cell only (i.e., won’t work on 2 cells)?
Would it file down enough to fit an L2 (~21mm)?
Two of my lights (L2 and S11) have XHP35 HI and are using the H2-C 22mm 1.5A from KD, so your driver is very interesting.
Yes, that should work, the driver is just released, single cell driver for XHP35.
It should fit, since the L21a (21700 version of the L2) is the first to be introduced with this driver.
https://nl.aliexpress.com/item/4000056253432.html?spm=a2g0z.12010612.8148356.1.755c6d6cylPwhS
it runs on 18650/21700 battery ,
170KCD, 824meters
it runs on 1pcs 21700
L21A XHP35 820meters
L21A SST40 720meters
22mm ,it only can be installed in L21A
Boy does THAT sound like a challenge…
Just ordered 2. I love a challenge
Can l2 throw 2000lm all the time?
Can it work on 21700 battery?
Or is there any other convoy flashlight under 50€ which can do this?
For 21700 , there is the L21A version with XHP35
I don’t know if it has temperature stepdown, otherwise removing the NTC on the driver will disable it.
Removing temperature stepdown wont solve the problem, cos then you cant hold it in your hand
So tldr:
2x21700 big flashlight with good cooling and over 2000lumens
Size and weight isnt problem
2400LM,
no adpater for 21700 battery
So 2x 26650 version can also work on 2x 21700 without adapters?
Is it able to be cold enought to hold even on full 2400lm mode?
If yes I am going to order one right now
abgx1, why 21700? The Golisi 26650 almost matches a 30T and has 50% more capacity.
You will need to make a tube to prevent battery rattle if you go with 21700’s, roll up thin cardboard or something…
Its working with 21700 great, its not even rattling, as they are very long, so there is enought pressure from springs that they wont move
Any plans for releasing a xhp50.2 3v single cell version of this light?
