[Sale] 7. batch DD 1S/2S Bistro HD OTSM/NarsilM/Anduril drivers 12-47.5mm size S2+, C8, H03, MT03, Q8 Clicky or E-switch
FET+1 1mm copper ring around it so component area is 10mm
Does this have the same bistro fw as the 15+ mm drivers?
Also, can the copper ring be removed so the driver fits a 10mm cavity?
if you can connect ground and avoid shorts yes
Hey Lexel, do you have an Anduril driver which would work in a Nitecore D10 or D11? Stock drivers are 15mm.
may work but only with 3.7V lithium battery
Ofc. What options are there for 15mm with Attiny85 and Anduril?
3-4.2V standard Anduril with switch LED in firmware activated?
Yeah all standard. I can flash Anduril so settings aren’t too important but I’d be looking for efficiency/usable levels rather than hotrodding. There won’t be an illuminated switch. Hardware wise, is it FET+n+1?
Trying to figure out what needs to be done to make it work in the Nitecores atm. I was originally thinking it would be plug and play as the piston drive effectively acts as the e-switch? I can upload photos of the driver later if it will help.
From pistolsnipe on CPF , this is how they work:
the battery + contact remains in constant contact with the driver board, the spring on the - end of the battery keeps the piston sleeve out of contact while the head is unscrewed sufficiently.
as you screw down the head, the piston sleeve comes into contact with the brass ring, which powers on the light to whatever setting you last left it at
while the piston sleeve is in contact with the brass ring, you can press the sleeve in further by pressing on the rear, to bring the brass ring into contact with the driver board. the driver board, which already has power from the brass ring, through the spring, uses the brass ring to circuit board contact as signal information only, this signal means to ramp up/down or change modes in some way.
if you want to maintain momentary and constant on, you need to hook up your ground side of your led to the pill directly, or to the spring, as the pill and the spring will be ‘grounded’ by the sleeve touching the brass retaining ring (before the ring touches the driver board)
What board do you have that has the pickup ring for the switch (piston)?
I’m needing a new driver for one of my lights. Here is what I am looking for:
  • 21mm FET (or FET + 1)
  • 2S output (for a XHP70)
  • E-Switch with tailcap compatible
  • No bleeder
  • Anduril Firmware
Let me know if you have a driver that would work for me. Thanks!
I also have a D10 and I’ve been looking to mod it with Narsil or Anduril too!
My question about these drivers is about the 7135 chips on the back! I’m afraid that they don’t fit well with the contact ring…
In case you advance with this option, please let me know how it works!
I will also change the LED, of course :stuck_out_tongue:
Nitecore D11 driver - click to supersize
I only have a couple of 219Bs (scavenged from Astrolux A01s I bought back in the day) and have put one in my D10 :heart_eyes:
Hi Lexel,
I’m looking for the following:
22mm FET+1
1S
E-switch
Anduril
Is single sided an option?
Also, the light it’s going into will require me to shave the driver down to around 21.2-21.5mm. How wide is the contact ring around the edge?
Thanks!
This looks like the top side ground ring is in fact an e-switch contact?
I have a 20-22mm variant with wider ground ring
Looks like it? Here a few more pics which may help. Not sure if the ground ring touches the big solder blob. We can discuss over PM if you want? Save your thread from getting cluttered up.
I’ll take two!
What does 1S and 2S stand for? One-sided and two-sided? :blush:
1s = single cell (4.2v)
2s = two cells in series (8.4v).
A 2s driver is not a buck driver for running a 3v les off 2 series cells, they’re all linear drivers unless specifically called something else*, the led voltage has to match the input voltage.
*Lexel does have some buck drivers.
Hey Lexel, let me know if you need any other info from me. Thanks!
Hi Lexel do you have a driver for BLF GT with a xhp70.2?
