Is 4000K version already sold out? Or will it be available later?
I didn’t even know this was a thing. I might get the 4000k if it shows up. My only experience with the 6500k SST-20 is miserable. Horrible green tint and super low CRI.
:o whaaaaat
Might just mod my existing ones, but any more I get will be sst20 when it’s avail in 4000k.
I have C8A driver that randomly starts flashing as if low voltage warning or something. Usually locking it out then back on resets it but it gets annoying . I know of a few posts about the same problem before. Short of removing the driver, is there a cure for this and has the problem been addressed in later ones?
My Sofirn headlamp just did that. I wonder if a battery swap might help. I haven’t had time to check though.
Oh as in the red LEDs? It’ll be to do with it thinking there’s a ton of resistance - reseat all the springs if possible, and try and feel for other spots that get hot where they shouldn’t. My SP40 did that when I installed a magnet cause I didn’t have the spring siting right; pushed it back in solidly and it was fine.
When is Sofirn going to start using those LH351Ds in more lights? I would but several models in a heartbeat if they used that or SST-20 4000K.
I’m dreaming about SST-20 4000K version of SP31A with direct access (by long press from off) to true firefly mode (3 or 4 lm) and direct access (by double click from any mode) to turbo.
Strobe could be hidden in next double click after turbo.
I love very first SP32’s runtimes. Especially 918hr in firefly mode. I don’t think sofirn has any other light that can run longer on firefly mode.
Did anyone test the 918 hour?
(Quick calculation: 3500mAh/918h=3.8mA. If the driver has no leaks, the MCU eats at least 2mA, so 1.8mA leftover for the led with which you can make 0.8 lumen max, not 3 )
New design, variable temperature color EDC flashlight.
2pcs LH351D 6000-6500K and 2pcs LH351D 2700K
TIR optics, Type C USB port and with indicator.
Very compact 16mm length only
Photo comparison to C8G.
Source: Sofirn’s facebook page
Perfect for 4* SST20 high CRI 21700 version with Anduril (IMHO)
I’m gonna guess… that’s 106mm length? Not 160mm. But definitely not 16mm either
Cool. Good to see more USB-C, and I see the LT1 tint-mix theme is spreading. Mix it to 4000K-5000K and the average should be nice. It beats slicing dogfarts…
Sofirn in the house!
That looks like a winner right there.
Hello Barry,
Excuse me for coming (maybe) late, and asking a question:
Will the SP70 BLF version include better emitter choices, than the current non-BLF version SP70?
Nice! tint ramping? Probably, they directly applied the Lantern firmware I assume.
Yes, you need a special UI for tint control and I don’t think Anduril is designed for that.
I thought Sofirn already had a developed tint ramping UI in one of their lights a while back?
Hope no only black once again
It could also be 116 mm.
With a thinner bezel and powerbank capabilities it would be a must-buy. As it is I find it interesting but not special.
not sure i understand why u want 2 cool white and 2 ww leds??
Tint mixing, and superb dynamic range with 90CRI LEDs.
It’s what the BLF lantern does.
