Your torture tests video are exciting and fun to watch. Looking forward to the 9mm and the 20g bird shot test…? Juuust kidding lol
Now I really want to shoot the production 7075. Not sure if I can afford to but friend has all calibers up to S&W500. He said 9mm would be a breeze and he knows his metal since he is the one at the shop.
Even I’ve confused SKY69 for myself. Several times I saw his posts and was shocked I ever posted that only to find shortly after it wasn’t my post. :person_facepalming:
SLN Serial 000 Proto V3
Machined engraving help preserved the marks that laser engraving otherwise wouldn’t
I just perform the heat test and the results were extremely surprising. While video is uploading give me a guess on the following values:
Ambient temperature 67F
Light engine Quad White2 + VN4 with thermal protection disabled.
Manker 4800mAh 21700 tested cell
2500L at 30s
Time in Min until “too hot to hold”:
Time in Min until peak temp reached:
Can circuitry handle heat nonstop?
Max start up lumen:
Test ending lumen:
Free Tange V2.1 in your choice of color for top 2 closest guess.
That’s one nice light Vinh.
Originally Posted by LarryB View Post
“Wow, you really are trying hard! Doing a burn-out over it parallel was bad enough, and even though 6061 is soft, the hard ano was enough to protect it, and you didn’t scratch the ano! Perpendicular was asking too much for the 6061, it’s just too soft. 7075 would have had problems as well, but the scratches would have been much more minor, it’s MUCH harder than 6061. Other than some of the other really expensive lights made by small makers like us the lights are 6061 or sometimes 2011. The main advantage of 6061 is corrosion resistance, which is why it’s used in aircraft, but it’s soft and lower in strength than either 2011 or 7075. 7075 is getting up close to steel in its characteristics, but is VERY expensive, which is why it’s not used in many if any high production flashlights. As long as the flashlight is anodized and/or alodyned, corrosion resistance isn’t an issue.
Since you seem bent on destroying it, you should really keep going after you hit it with your high powered pellet rifle. I’d go for 22, then 308 and 9mm. Even though it’s 6061, it’s strong enough that I wouldn’t be surprised if it gets as far as the 9mm. Who knows, it might even handle the 9mm. I’m pretty confident that the 7075 will survive a 9mm if you don’t hold it fixed solidly, and who knows, it might even survive that. If you had had the 6061 versizn glued down to the asphalt strongly enough to keep it from detaching during Phuong’s burn-out, I doubt very much that the hard ano would have been fazed.”
Our man has finally spoken! Mr. Larry is the man behind all of the computer design. On our road trip to Cali last summer Phuong and I met up with Mr. Larry and his wife for dinner to thank him for a huge purchase that he made to help me acquire my engagement ring for Phuong. Some of you might have remember that the sale close prematurely as be bought all of the lights from the sale to help me out. During dinner Larry proposed that its finally time I should build my first light. He volunteered his time and expertise with computer design and machining FREE OF CHARGE! We got SLN today 50% due to Mr. Larry! I likely contributed 10% to the left over 50%.
A dear gratitude to the man that have done everything for us without ever asking for anything in return. The man that has put up with my countless request for changes in design and unreasonable requests. The man that made all my talk happened. Thank You!!!
Vinh&Phuong
The main difference between my posts and SKV89 posts are SKV89 posts are from someone who knows what they are talking about where mine are from a technical moron who just loves nice flashlights.
Mr. Larry forgot his username so he cant log back in to post. Does anyone know how to recover username from an email?
top left “contact the admin” probably a good start
SL Nguyen Flashlight Torture Test 5: Heat Test
Time in Min until “too hot to hold”: 7min
Time in Min until peak temp reached: 11in
Can circuitry handle heat nonstop? YES
Max start up lumen: 2650Lumen
Test ending lumen: 1890Lumen
I assume it’s a FET driver but I would expect slightly higher max lumens so it makes me think maybe some resistance there.
Not a big deal, it might be worth it to allow the light to run cooler. However, I would run the turbo again for a few minutes and unscrew the light and see if those springs are getting hot to the touch. If they are they might sag your springs or kill your switch over time?
IDK something to consider.
All noted
@vinh, are you using a mechanical switch, or an electronic tailswitch?
Mechanical
Why does your quad w2 d4svn produce 4600 lumens and this quad w2 only does 2650 lumens?
Nice work Vinh! Definitely interested in this. Been following your website & Youtube channel for years.
Likely low drain cell. I will try another unprotected.
Nice work Vinh! Definitely interested in this. Been following your website & Youtube channel for years. :+1:
Thank you!
