About 23.8mm
A special light engine is in design just for this custom MCPCB to be used in SLN
I might use it in other lights as well
I might ask Richard to help me sell some as I don’t sell parts to avoid stepping on his toes
Nothing is decided yet and the MCPCB and copper light engine for it is still in design
IMHO you can avoid batteries looking like that by separating the connected-at-all-times aspect of the spring from the absorb-the-total-impact aspect.
Absorb the impact by, let’s say, a fat soft rubber cylinder shaped ring around the spring.
That way the fully compressed spring does not have to behave like a steel nail.
The soft ring can deal with unbelievable forces, because it is surrounded by a massive tube.
Just saying. The spring only has to deliver the juice. Give it some body guards.
But maybe you already have thought of that and I’m only kicking in an open door (Dutch expression).
I modded a Hounddog or something like that sometime ago and I remember this light was excellent in build quality and design. This is my debut light with simple designs which is not on the level of any major brand.
Yes, Vinh, this is a good idea. Malkoff, for example, sells thick o-rings to be placed around the springs, known as “battery bumpers.” The idea has been discussed before, on the other flashlight forum (search for battery bumper), and perhaps here on BLF, as well. These bumpers are often a simple user add-on, using various common o-rings. Back in the 2000’s, Peak used to accomplish the same thing with neoprene “donuts” glued in place.
EDC only if this is ur duty/work light. It’s too big n heavy for a light u keep in your front pocket just for emergency. There r way better lights for that.
I played catch-up on this thread today, and quite enjoyed it. Your destructive testing and the lights persistence to continue working is nothing short of amazing, what a BEAST of a light. If you can think of a test using our waterjets, I’d be happy to accommodate anytime.
So well done man. Your enthusiasm and passion for this project is infectious, truly inspiring. I’m definitely interested in the finished product, especially knowing your Lego intentions down the line. Good luck on your remaining steps and hope to talk soon.
