Test/review of Xtar PB2S Charger & power bank
Around 0.1mA, but there is a curve showing that at 2.5V on the battery it increases to 5mA.
Thank you.
HKJ: the low current hidden mode works ok? Or does it have noise in the output?
Oh, that’s interesting! I went looking for more info about the low current mode, and the ZeroAir review:
has a picture of the user manual. Quoting from that:
I have a couple of small devices that would be useful for :slight_smile:
Calvin from Illumn shared that with us weeks ago.
I’ve been looking forward to this test, and appreciate the insights it provides.
XTAR did much to address the weaknesses of the PB2, and while not perfect, what other product out there can offer the combination of capabilities it has? Or better it? From a widely distributed, reputable brand name?
Serious question.
I had missed that low current mode, the review is now updated with it.
No worries…
Interesting to see the behaviour at that hidden low mode…. Waiting for the update.
Btw… Thanks for all your hard work
I have updated, there is no new curves only a few points extra in the power bank section.
What it does is disable the low current shut off.
Thank you Sir!
HKJ
So if I wanted to use a solar panel to recharge the battery’s once the solar panel quit charging due to clouds or whatever it would need to be powered cycled to resume charging?
Thank you
No, I show it in this chart:
The “brown out voltage” at the bottom is how low the output from the solar panel vent.
The cyan dots shows what happens during the low voltage and the red dots show what happens when the voltage returns to full again.
On the PB2S the red dots are at full current all the time. It do not matter if it was a small or large voltage drop, it will resume full current again when it is over.
That is another good point about it… Still expensive… Hope it gets lower price
Thanks for the extensive testing, did you do some USB PD tests as well (or anybody with this device)?
Mine sadly has USB PD issues (voltage drop and eventual reset) and I wanted to know if this is sort of common. Sadly I don’t have a QC compatible device at hand, I’ll try to get one.
I did run a load sweep:
And a test at 5V 2A:
I did not detect any high voltage support on the USB-C connector.
Hmmm… Maybe Xtar will release an updated version??
Ah, now I noticed, on your device there is no mention of USB PD. Mine has a different marking, PD is mentioned with the “USB-C Output” - the ad on aliexpress also states the PD In- and Output capability. And it works in principle - with both of my USB PD devices (Pixel 3A and Thinkpad X280) it puts out a higher voltage. Just when the devices draw a little more current (above 1 A) the voltage drops and the PB2S turns off (and restarts in 5 V mode). 5 V mode works, but at 1.9 A the voltage also starts to drop to 4.7 V on the devices meters.
EDIT: With a Samsung QC phone it sits at 8.8 V and 1.2 A. Tremendous situation, don’t know if the phone is just happy and doesn’t want more, or it doesn’t ramp up further because it detected voltage drop. I ordered a USB PD cable I can splice into for adding a multimeter and/or additional load. But thanks for the helpful answers so far!
Specs on the back side of the Xtar PB2S indicates PD3.0 support
Unfortunately I don’t have any PD3.0 supporting device for now.
But have the ZY1276 USB meter.
I was able to do PD3.0 trigger, as shown in this video (unfortunately, I can’t seem to replicate how I did it now, since the ZY1276 USB meter doesn’t want to show display when I do the same setup now…)
Here it shows the complete protocols detected (USB PD3.0)
Sometimes it doesn’t have USB PD support)
(in another try, it misses the Apple protocol)
All above were tested using a (BlitzWolf) USB-C to USB-C cable from USB-C port of PB2S connected to the USB-C “In” port of the ZY1276 USB meter.
I made a breakout board to connect my multimeter and a few switchable resistors do add load (if the device throttles because of voltage drop). First thing, the amperemeter of my unit reads way low (300-400 mA). It doesn’t matter how you trigger the higher voltage modes (QC or PD), it always behaves the same.
I managed to get 14.5 W out of the unit in both 9 and 12 V mode. In 12 V mode you can actually draw 1.4 - 1.5 A, but the voltage has dropped to about 10 V at this point. More than that and resets. In 9 V mode it didn’t drop as bad, but at 1.7 A it cuts out. My phone seems to see “oh I’m connected to a 18 W PSU, I’ll draw 18 W which therefore leads to an instant cut-off with the powerbank. I’ll measure the current the phone draws from its original mains adapter as soon as the battery SoC is low.
I got a full refund on my unit.
EDIT: Pixel 3a draws up to 1.9 A in 9 V mode.
