Oh okay nice! I’d be interested in 25 3400k and 25 5600k if ever you plan on getting the 5600k and if I can do that(I don’t want to mess up your inventory since you only ship 50 per pack). As DavidEF suggested I just plan on mixing these for a neutral temp.
The reason that I didn’t plan to go for 5600k is that Yuji still sells 5600k 5mm (and I believe there are still some of these or similar clones selling in the wild). I don’t plan to step on their toes (yet). But if enough people want me to do it, then I will do it, no objections But maybe I will, after the 2nd batch.
If you wanna shop batteries at FastTech better pack some battery items together, saves money.
The battery shipping subject did a lot of harm to sales of harmless batteries and harmless battery powered stuff. I'd buy small shipments of alkaline or silver coin cells from china in the past and while it still is possible for cheap, it's not that easy.
Some sellers (in AliExpress) just @#$% with the “selected carriers for batteries” thing and ship the stuff declaring it to be something else, at least sometimes I think.
A lot less than 25mA on average, this is for sure. The actual power delivery efficiency is quite low, such cells aren't designed for high drain. Simplicity and reliability are the main factors here.
Even the “half watt” LEDs can’t reach 45 lumen output. They are generally only rated up to 100mA @ 3.4V, which would translate to 0.34W of power. To get 45lm out of that, you would have to be getting over 130 lm/w efficiency, which none of these LEDs have. The cheap LEDs in this format are only good for 20mA current. Perhaps they meant 4.5 lumens? That would actually be the likely output of standard LEDs in this format.
Well, that usually is their rating. Months ago I did some testing on a bunch of 5mm and 10mm leds I had lying around, bought in 2006 or so. The 5mm ones would start dieing at 140+mA, and the 10mm ones slightly higher at 180+mA if I recall right.
So, they could be hard driven to some extent (100+mA pulse driven successfully).
It is the same keychain light as the Astrolux TB01, that had a bit different type of 5mm led than usual, with extra thick leads. I never measured the output before modding it but it could have been 45 lumen (so maybe 120mA).
So, Barkuti and djozz, are you guys implying that the light in question is actually using a “half watt” LED and overdriving it, in order to get 45 lumens out of it? That would be a strange thing to see. Can somebody test one to find out what the output really is? I’m really curious now.
