Mr. Light Gangster 250 - Need Advice
11 posts / 0 new
Yadu2323
Last seen: 2 years 1 month ago
Mr. Light Gangster 250 was gifted to me by a friend. It only works on high which lasts around 2.5hrs & heats up too much.
Full specifications are not available.
Need to add modes to it so it works for a longer time.
Can anyone advise which parts would be the best fit?
Edited by: Yadu2323 on 10/07/2019 - 15:57
Lexel
Lexel's picture
Last seen: 1 year 3 weeks ago
850 lumens in such a big light and you say it heats up too much?
Henk4U2
Henk4U2's picture
Last seen: 35 min 42 sec ago
If THIS is the light you are talking about I’m amazed that it even gets warm!
If so, I suspect that will be only in the area were the head is attached to the body of the light.
Unless there is not enough aluminum involved for properly absorbing and conducting the heat of the XP-E2.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 11 min ago
Actually, you want the light itself to get warm, else the LED gets all that heat bottled up ‘til it gets sick and dies.
If you want to replace the driver, either someone else here has to have the same exact light, and/or you’ll have to open it up and take some measurements.
Looks like a big honkin’ Maglite, so dunno if it has multiple modes or if it’s in fact supposed to just be off/on. Didn’t see any “modes” listed anywhere, so it might be just that.
Sirius9
Sirius9's picture
Last seen: 1 day 13 hours ago
Gangster LED Facepalm
Henk4U2
Henk4U2's picture
Has more street-rep than Uranusfire, I guess.
Muto
Last seen: 1 hour 50 min ago
Gangster LED brought to you by Boost mobile ! Smile
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Lightbringer
You gotta hold the light sideways when shining it.
JaredM
JaredM's picture
Last seen: 6 hours 8 min ago
Big Smile
Yadu2323
No modes. Just on max.
Throw is very good & brightness seems to be more that 850lumes as compared mine with a friend’s nitecore 1000lumens.
Mine seemed better.
Yadu2323
Have tried desparetly to open it up but failed.
Centre piece contains circuit PCB, button, recharging port & led.
Not able to figure out how to remover those components. In the process broken soldering of the led
