Got mine a few days ago and I’m really impressed. I ordered a silver 5000k but asked if they could send me a green one instead and Banggood came through. Very happy that they did, the color looks great. I do sort of wish I’d gone for the 4000k but I have an MF01S in 4000k so I figured I’d try a different temp this time. It’s nice but not as nice as the 4000k; oh well, live and learn.
I have ordered some Shockli IMR 26650 from banggood and those should be the same cells you mentioned just rewrapped (from what I heard). But I have those 2019 Liitokala 26650 I bought for a different flashlight and wonder to what extent I can use them in this one and what I can get from them.
Output on turbo woold be lower but should keep up longer. We need some test to really know. The battery would be worn down, capacity lowered, faster but with turbo being so short it might not be too bad.
The black Liitokalla would be an alterntive inbetween them.
The Vapcell look very expencive, it is just for one battery.
The 5100mah are junk. Typical unknown cells. Probably work okay, but have a lot of voltage sag. No one has tested these other than your common battery charger capacity tests which show that these cells vary a lot. It’s not a good sign. They may be using a variety of cheap 26650 cells under this wrapper.
Your probably thinking of the older blue 5000mah LiitoKala. Those where the good ones. They don’t make them any more. They switched to the black and gold which were also goid. Unfortunately, these are sometimes faked, so you have to get them from a reputable source. Due to these factors, it might be best to go with a different brand 26650 cell.
I just picked up my Green MF01 Mini today and it’s awesome! It’s SST-20 5000K which is pretty nice but if I get another, it will be 4000K.
I love 26650 lights for the vehicles or in the house as opposed to multi-cell lights. They have a great balance of runtime and output. I was planning on getting a MF01S but I think I may get another one of these.
You’re probably right, the 40T was the one I was originally going to get, but I must have mixed them up when I ordered it. On the other hand, I only use a torch for about 20 minutes each day, on a modest setting, so I don’t need to recharge my batteries very often.
EDIT: After years of using them, your comment only just made me realise that the first two digits of Samsung’s Li-ion batteries describe the capacity! :person_facepalming:
Yodel have to be the worst delivery company i have ever come across. When i saw my order was at “Hatfield Terminal” i felt dread as I’m very familiar that it is their main warehouse. Apparently my item is in Birmingham at Sandwell. Will expect the usual “delivered to a safe place” meaning they threw it on the floor outside the house delivery.
Same here. I’m actually suprised that the delivery driver buzzed today - they usually just leave the parcel outside my door without even checking if anyone is in.
Yodel have been grouping my deliveries of late, which I suppose is efficient. No tracking of course and the online help is always busy. I have had parcels left behind the bins, and once, in the bin, and another time under my car. I know the drivers are under huge time pressure.
Thanks for the info re: configuration of the Aux-LEDs brightness.
Aux LEDs at 15-18mA = must have been quite bright to consume that much power. At what current did you finally configure your aux-LEDs to, to make them more “visible” than the default (I notice the aux-LED brightness are really quite dim, coming from the factory default (I measured 0.42mA with a DMM, I think this is already on the “High” setting).
I used a Lii-50A (black/gold) for testing which is not as good as a Shockli/Vapcell, and got around 7 Amps on Ramp Ceiling and around 19-20 Amps on Turbo (I think it could be higher since my copper wire might not be as thick as possible for amp meter measurement).
Other things I noted:
- on battery insertion (in stepless ramping mode): this will be in 1x7135 regulated mode (NoPWM)
in stepped ramping mode, default 7 brightness levels, only the 6th step is the regulated mode, which I’m measuring 2.24Amps (could be my amp meter not that calibrated anymore) — since this seems to be 6x7135 or 7x7135 regulated mode (NoPWM). (if 6x7135, that would have been close to 2.1Amps and 7x7135 would be 2.45Amps, but I checked with a “shine light through portable fan” method, and only the 6th step in the stepped ramp mode does not have PWM).
So there are 3 levels when there are NoPWM:
must be in stepless ramping mode: on battery insertion = NoPWM (this 1x7135 level is not present in the 7 steps of stepped ramping mode) ~ 0.32A
in stepped ramping mode: the 6th step is also NoPWM ~ 2.24A
in Turbo mode: NoPWM ~ 20A
(I think my amp meter has a calibration problem, 1x7135 should be 0.35A but I only get 0.32A readings out of several other flashlights too when using 1x7135 level)
