Thanks for the info re: configuration of the Aux-LEDs brightness.
Aux LEDs at 15-18mA = must have been quite bright to consume that much power. At what current did you finally configure your aux-LEDs to, to make them more “visible” than the default (I notice the aux-LED brightness are really quite dim, coming from the factory default (I measured 0.42mA with a DMM, I think this is already on the “High” setting).
I used a Lii-50A (black/gold) for testing which is not as good as a Shockli/Vapcell, and got around 7 Amps on Ramp Ceiling and around 19-20 Amps on Turbo (I think it could be higher since my copper wire might not be as thick as possible for amp meter measurement).
Other things I noted:
- on battery insertion (in stepless ramping mode): this will be in 1x7135 regulated mode (NoPWM)
in stepped ramping mode, default 7 brightness levels, only the 6th step is the regulated mode, which I’m measuring 2.24Amps (could be my amp meter not that calibrated anymore) — since this seems to be 6x7135 or 7x7135 regulated mode (NoPWM). (if 6x7135, that would have been close to 2.1Amps and 7x7135 would be 2.45Amps, but I checked with a “shine light through portable fan” method, and only the 6th step in the stepped ramp mode does not have PWM).
So there are 3 levels when there are NoPWM:
must be in stepless ramping mode: on battery insertion = NoPWM (this 1x7135 level is not present in the 7 steps of stepped ramping mode) ~ 0.32A
in stepped ramping mode: the 6th step is also NoPWM ~ 2.24A
in Turbo mode: NoPWM ~ 20A
(I think my amp meter has a calibration problem, 1x7135 should be 0.35A but I only get 0.32A readings out of several other flashlights too when using 1x7135 level)
I don’t think we have seen the driver, yet (have we?), were told it’s 3 channel. I assume it’s using 7135 chips. If so, what your calling no PWM is basically 100% PWM which is like a solid signal. So all 3 channels use PWM, it’s just not visible when any of the 3 channels are maxed out. You might already know this, I just wanted to clarify for other people.
Also, when channel 2 is active (maybe 6 chips?) remember that the single chip on channel 1 is also going at 100%. It’s quite possible Lexel used 0.320 regulator chips. This makes sense for your channel 1 amp reading and if channel 2 is 6 more chips (1+6=7x0.320=2.24). Maybe we figured it out?
My clamp meter at home that I used has a lowest range of 2A, my measurements might be a little high for the AUX LEDs at max brightness. I will take a look at this again when I am in the office where a I can use a Fluke DMM with a much lower range.
Here is my latest reading from my company FLUKE 87V DMM (this is calibrated once a year).
AUX LEDs at MAX brightness - 7.3mA
AUX LEDs at MAX brightess except green (very low) - 5.33mA
AUX LEDs at okay brightness - 2.8mA
AUX LEDs at Low mode - 0.28mA
The results are much better because this meter can measure in uA and mA. At my current settings, 5.3mA, it will take 1000 hours before I fully drain my 5500mAh 26650 battery.
That’s half of it. Looks like FET+6+1. Need to see the other side to make sure. There could be more 7135 chips on the other side as well as the MCU.
Looks like regular 7135 chips. They are usually available in 350 or 380 mA ratings. I wonder if they offer a 320 mA version. I’m not sure what that sense resistor R6 is for. You don’t typically see those on FET drivers. It might be tied to that chip above it. Maybe that chip is related to the charging circuit?
You would probably need to unsolder 5 or so wires. No big deal if you don’t want to do that. Eventually someone will pull the driver out and we can see the other side.
I’m soooooo happy with the light after taking it out with me last night. That 4000K tint is definitely the most pleasant that I’ve seen so far, and the output is simply stunning for a light that I still consider ‘pocketable’ (i.e. coat pockets, not trousers!).
I adjusted the trimmers to increase the brightness of all AUX channels, with the effect that now only green is visible in low mode, but I’ll be reading through the comments on here to see if I can adjust the brightness levels so that the blue and pink LEDs also light up.
A big Thank You to Freeme for making this group buy possible!
I’m also excited for my 4000k full copper to arrive. I only have the 6500k tint for now.
For the issue of the AUX LEDs in low mode, please do the adjustment when in low mode. Lower down the green brightness slightly until the purple and blue lights up.
Just received my light (same day as the EDC18). They hit a home run with this one. I thought I had ordered the green one but received the grey. I’m not disappointed though as this one is beautiful. Love everything about it. My voltage reading appears accurate (haven’t tried charging yet). The aux led’s are beautiful (no adj needed) and the sst20 4000k appear as good as my FW3A (but will look closer tonight).
Fit and finish seem top notch too. I am a happy camper!
Wow, 8 wires going to the head. Did you have to unsolder all 8 or just the 2 led wires? Does the switch come out in one piece?
Yep, it is FET+6+1. A very different looking layout from the TA drivers with the charging circuit integrated in and not on a seperate board. I guess the inductor is for the charging cuircuit? We need a driver guru to explain it.
Edit, it does seem to be the basic TA driver design under all the charging components. The inductor is part of the charging circuit. Lexel using the good Vishay SIR800DP N-Channel MOSFET
I unsoldered only 5 wires:
LEDs: thick black and white
AUX: red, black, blue
I don’t need to disassemble the button and I don’t want to do it. I usually scratch the flashlight…
Switch led - gray
Switch - yellow
“+” - white
“” green
”Ch” - orange (I guess it’s “Charging” indicator)
“St” - brown (dunno, but it seems to me that it could also be a charging indicator)
I also think this inductor is charging component. The basic driver on which Anduril doesn’t need such “gadgets”.
So 4 of these lights came at the same time for me. I’ve had some time to mess with them tonight. So far initial impressions:
1) Build quality is definitely not as high as FF E07. I guess it makes sense since it’s got more features but is less expensive than the E07. E07 is actually one of the highest build quality lights I’ve handled so it’s hard to beat that. I was secretly hoping this would replace my three E07’s, not quite, this kinda makes me appreciate how well built they are. If anyone’s used a E07 you can feel how hydraulic the 21700 going into the tube is because it’s fit so snug in there. These MF01 minis don’t quite have that w/ the 26650’s.
Unfortunately I also feel the standard-sized MF01s’s have better build than these as well. My two MF01s were almost as good in terms of fit and finish than my D18.
2) 4000k tint seems to have some rosiness in it, and more white than FF’s equivalent in their E07’s and 5000k is still significantly green at low levels
3) I love the feel of the button, this is where it trumps E07’s equivalent for sure.
4) Optics are solid, good mix of throw + flood where it’s throwier than the E07 but floodier than D4s.
5) I put a Molicel P42 21700 in one, compared with a LiitoKala 5000mah 26650 in the other; from a pure visual aspect out at night, I can’t tell a difference (I know someone tested 21700 to have output than 26650, but not in my case visually). So… I think it’s moot to use the 21700 batteries in them. It did get hotter quickly though.
(Edit: compared these a few rounds and there seems to be a slight brightness increase w/ the 21700, an effect that’s so minor you’d have to really pay attention and not move the light around to see. It’s not worth the faster heat up rate)
