Ah I see it. Thanks TK
So in order to keep the switch led on low, am I correct in saying that I can’t just un-define USE_INDICATOR_LED_WHILE_RAMPING but would need to set indicator_led(0)?
Sorry for the delay.
I think you could probably just replace indicator_led((level > 0) + (level > MAX_1x7135));
with indicator_led(level > 0);
. That should keep it on low whenever the main LEDs are on.
No worries at all and thanks for the confirmation
Is this the perfect location for speaking in general about the UI?
What I like or what I don’t like…
If not, please suggest me the right thread
Thank you
TK, I have my own branch with a number of commits. I’m new to bzr and it causes me a lot of troubles…
I’d like to upstream 3 minor tweaks. How do I organize the repo to do this well? Should I have a feature branch for each of them (note that the 2 smaller paches total 3 lines and the third is larger but nevertheless very minor)?
There are lots of ways it can be done. The easiest is probably to just commit the changes, if you haven’t already. Then push the branch up to Launchpad. Or if you don’t have an account and don’t want one, you could send me a diff (or three diffs) or a copy of the branch.
If you have an account, it’d be something like this:
Then make a merge proposal on Launchpad, or otherwise let me know there’s a thing waiting for review.
If you don’t have an account but are okay with making one, it involves creating an account with a web browser, creating a ssh key, uploading the ssh key, then telling bzr to log in. The last two are done something like this:
I really should move things to github though, since it’s so much more popular and more actively maintained.
On a different note, I made a bunch of kernel-level changes recently, and published the code and .hex files today. It still needs more testing before it can be considered stable, so any help with that would be … helpful.
So far, everything seems good except that thermal regulation might behave a little differently. It shouldn’t be any different, but each test run produces slightly different results… so it can be a little hard to distinguish between an actual change and a random expected variation in behavior.
The changes include a complete rewrite of how interrupts work, plus a bunch of other changes to the plumbing for how FSM works. This makes it a high-risk change since it affects so many things. However, there shouldn’t be any visible differences in the user interface. If anything, the only visible difference should be a general lack of glitchy behavior. I fixed most of the race conditions and other inconsistencies which could occasionally happen.
https://code.launchpad.net/~nisjuk/flashlight-firmware/nisjuk
Revisions 451, 452, 455 could be interesting for you.
I did a bunch of changes to tweak the UI more to my liking.
I have one problem with it though - some configuration defaults don’t suit me (particularly aux LED config) and I don’t see a way to change it. Is there a good way to change the default config?
Thanks, those look useful.
-fwhole-program
flag changes how the linker works, and appears to save a significant amount of space without changing any functionality. I’ll definitely be adding this, since it provides space to do other things people have been asking for. I suppose it depends on what exactly you want to change.
I’ve been meaning to go through and make sure each of the USE_ flags can be set or unset in the config files. This would mean that, for example, people could copy cfg-emisar-d4sv2.h
to cfg-my-emisar-d4sv2.h
(or just #include
the upstream one in the personal one) and then change whatever they want, producing a custom version without needing to make changes which could get overwritten by later upstream revisions.
For example, it might work to have a cfg-my-emisar-d4sv2.h
which looks like this…
#include "cfg-emisar-d4sv2.h"
#undef USE_BIKE_FLASHER_MODE
#undef USE_PARTY_STROBE_MODE
#undef USE_TACTICAL_STROBE_MODE
#undef USE_LIGHTNING_MODE
#undef USE_BEACON_MODE
#undef USE_MOMENTARY_MODE
#undef DEFAULT_LEVEL
#define DEFAULT_LEVEL MAX_1x7135
#define USE_DEFAULT_AFTER_LOCKOUT
Or something like that.
If the UI options are desired on a bunch of different lights, those parts could go in a “my-cfg.h” and then include that in each custom build target, to avoid duplicating the same code a bunch of times.
When I said config I meant “whatever is in eeprom”. It gets reset upon every flash - and to values that don’t work for me.
Though that custom cfg file is a good idea, more maintainable than what I’ve so far.
You can set the EESAVE fuse so that the EEPROM is not erased during flashing. But then you have to make sure that the addresses of the variables stay the same.
Thanks. Manual configuration every time I change EEPROM format is way better than every time. Though if there was an easy way to change the defaults - that would be great.
Ah. If you just want to change the default runtime configuration, like the stuff a user can modify by pressing the button, that can be done in the cfg-*.h file.
#define RGB_LED_OFF_DEFAULT 0x18 // low, voltage
#define RGB_LED_LOCKOUT_DEFAULT 0x37 // blinking, rainbow
That’s it, thanks you
Anyone know how to disable thermal control with anduril?
I can’t seem to change it even after following the manuals I have found.
I click 3x, then 2x, 2x, 2x, then 4x to get to thermal config according to this diagram: Updated Anduril UI instructions for Aux LEDs - Imgur
It gives me 2 menu option, then first I have tried everything from 1 click to 30 clicks. Then I just click the 2nd option 50-100 times to try to set the temp high enough it will never kick in. Yet it still kicks in almost instantly when the light is still cool to the touch.
To completely disable it, compile with something like this in the config file:
#undef USE_THERMAL_REGULATION
Thanks, I might have to do that, was just hoping for a quick fix without having to take it apart.
Otherwise, get it hot, calibrate the sensor to tell it it’s only 1 degree, and set the ceiling as high as it can go… 70 C or 40 clicks. That should give it a lot of headroom.
Not guaranteed to completely disable regulation, but it should at least reduce the chance of ever stepping down.
Yeah, not worried about it never stepping down, it just steps down way too much right now.
