Actually, it’s really not that important. Terminal voltage will be exactly the same across all cells. Higher capacity cells with higher internal resistance will self-limit as that resistance acts as a ballast. It’s like having 3 water-tanks — 1pt, 1qt, 1gal — with hoses joining all them at the bottom. They’ll all fill at their own rate, and the level in each tank will be exactly the same.
The reverse happens when discharging. Voltage will sag in lower-drain cells so they won’t discharge as fast as higher-drain cells.
That said, and to keep from having to write a separate reply, most charging circuits pretty much use the same chipset, so there’s no real “better” or “worse” design. Same with usb chipsets (eg, voltage negotiation for usb-c).
Hell, whether it’s wifi, bluetooth, whatever, there are typically just a few chipsets to pick from. Almost no one rolls his own, as it’d just be reinventing the wheel.
I agree. It doesn’t sound like it’s the cable. If it was, you’d know the first time you tried to use it.
Definitely sounds like a defective light. Something went kablooie on the driver. Your options:
Return the light to Amazon for refund.
Contact Sofirn to let them know about the problem and to ask for repair or replacement. This might also enable Sofirn to figure out exactly what happened so they can fix it and others don’t experience the same thing.
You could ask Sofirn for damages. I doubt they’d pay anything for just having a headache without any further medical diagnosis. But if you spend thousands of dollars on a cleaning service, you could potentially ask for reimbursement.
If Sofirn fails to pay for damages you could try suing them. This might not be worth it if their office is not located near you. Trying to sue in another country could be a pain. Probably not worth the effort for minor damages such as caused by this. Before any litigation, it is a good idea to contact Sofirn to see how willing they are to work with you and make you whole.
You could try sending the light to someone on this forum for dissection and analysis. I’d recommend securing a replacement or refund before doing that though.
Yeah and there is also a Ruth’s Chris and an Arby’s in my town doesn’t make them equal quality. One way or another sofirn is doing things for 1/4 the price. After owning two of the lights it’s clear to me how they are doing it. Cutting corners.
I appreciate all of the advice here. I suppose I will just send this back to Amazon and hope the smell goes away. Hopefully this doesn’t happen to anyone else. I would have gladly paid three times as much for the light if it was better quality. I’m not really sure if I should worry about contamination with burnt circuit board fumes on everything or not. It made me pretty sick yesterday, but I did inhale quite a bit of it. I’m hoping that it will have no effect unless it’s inhaled in big quantities at the same time.
A Fenix that I bought 10 years ago had a perfect finish, came with very nice packaging, very nice instructions and has worked flawlessly for a decade. The sofirn showed up in a weird generic box. I could probably find a dozen imperfections in the anodizing. The machining was sharp. It worked for less than 2 weeks. Many things are made in China for political and cultural reasons that are beyond the scope of a forum post I want to write. My girlfriend is actually from China, and I’ve been there a handful of times. Most of the manufacturing is done in this particular region. It’s not just limited to flashlights. Great quality and terrible quality things come out of this region of the world. Unfortunately sofirn seems to be the ladder.
I think it’s also telling that both fenix and acebeam have a real warranty and real dealer network in the United States. These are people that you can get on the phone and talk to if you have a problem. I only know this because I’ve had questions about these brands not because I’ve ever had a problem. I’m sure there are other good manufacturers as well. Back in the late 90s when I was buying sure fires they seem to have pretty decent support even though an incandescent light is really not comparable to any of this stuff today. Anyway I learned a lesson with all of this. Stick to reputable, accountable manufacturers with a warranty. Even if the specs of a light look good if the price is too good to be true and the support is basically non-existent it’s not a gamble worth taking.
How do I contact them? I contacted the place I bought it from and actually spoke to someone on the phone at Amazon to inform them about the product. That was really the best I could do. I know I can call people when it comes to surefire, Fenix, acebeam and novatech because I have. to be honest I don’t know how good their warranties are because their products have been totally reliable for me.
Aside from all of this both of these sp36’s would get hot inconsistently on seem to step-down inconsistently. I was on the fence about keeping them before this happened but this certainly made up my mind.
It’s important to keep in mind that USB-C only refers to the connector.
The kitchen sink of protocols and functions that the USB IF has dumped in its lap ensures that it will never be fully mature or easy — by choice, as it keeps adding to that pile.
It may not be a total fecal show, but it’s not far off.
What most users will get out of it is that — it’s small, it’s reversible, and it’s not as bad of a physical connector as Micro-USB.
They will probably also get faster charging out of it — and these have to be conscious decisions — if the correct adapter with the appropriate protocol is used, and the cable is rated for fast charging.
Fast data transfer? Nope. Gotta make sure the cable is 3.2G1 or 3.2G2 (FKA 3.0, 3.1Gx), 3.2G2x2, or Thunderbolt 3 (their high cost makes this obvious).
The only thing any of these have in common is the connector. It’s up to the user to sort out everything else.
Much of it could have been averted if the IF had some backbone in defining minimum specs for a next-generation of connectivity, but it gave in to cost, and the lowest common denominator instead. A classic by-committee way of thinking.
I have the SP36 BLF Anduril version on its way. Should I be concerned about using the built in charger? Is there anything I could check for example with DMM?
