Lexel
(Lexel)
November 20, 2019, 11:20pm
238
This is just one of more driver related topics
I have plenty of information in the other topics, this one should list just an overview for current models
I have also a complete topic with guide for the 2 mostly used firmware, of course firmware got their own Topics especially from Toykeeper
JasonWW
(JasonWW)
November 20, 2019, 11:58pm
239
JasonWW
(JasonWW)
November 20, 2019, 11:59pm
241
Hoop:
Ok thanks.
See edited post above. That’s the order thread.
Agro
(Agro)
November 25, 2019, 10:05am
242
Since I got a D4SV2 I’m a big fan of Andruil with 1634 and RGB LEDs.
Lexel, do you have any plans to migrate some of your drivers to that architecture eventually?
Lexel
(Lexel)
November 28, 2019, 8:32pm
244
was not here listed for some reason
Acebeam K30 (with mirrored tail board)
MascaratumB
(MascaratumB)
November 29, 2019, 12:44am
245
Thanks for your work Lexel! Just to let people know, this will be used in the LT Tool 25 and in some other 2xAA (soon to be 2x14500) flashlights !!
Thanks again and I’m sure other people will grab these too
Lexel
(Lexel)
December 3, 2019, 11:03am
246
I think this will be the final version
about 3.5 hours went into the design
Can this driver be used to drive a UV LED in a Tool 25 with 2x 14500? Will it regulate the current until the batteries are depleted to 6V?
Hi Lexel,
Will this work with Acebeam K30 GT with SBT90.2 LED?
Lexel
(Lexel)
December 4, 2019, 11:41am
249
The FET has no current limitation, the small current resistors have current limiting function but no regulation and are only useable with 6V LEDs
No regular 6V XHP
Lexel
(Lexel)
January 2, 2020, 3:05pm
250
OP updated
15mm 2S drivers are now ready for production
I need one for my S42. Can you send me info on where I can buy one? I also have an issue with the charger in it. Can you replace this also?
Lexel
(Lexel)
January 26, 2020, 9:47pm
252
I cant replace the charging board, only option to use it without
Ok. Where to buy the board with the new ui?
I must be overlooking it but where do I buy the new driver from for the S 42?
JasonWW
(JasonWW)
January 28, 2020, 3:44pm
255
Send Lexel a Personal Message with your driver request info. It’s the blue button under his name that says “Send PM”.
oweban
(oweban)
February 28, 2020, 10:26am
257
Okay, so I’ve pulled apart my MF01 driver (the buck one, v2.1) that I got from you; everything’s working fine, just re-wiring it. Just testing with the DMM and I seem to be getting 140-150 ohms between LED+ and LED-. Unsure if that’s expected behaviour; seems to be happening on both sets of emitter wires. Open to thoughts! I’m reflowing it now on a heating platform in case I’ve done something stupid somehow.
OR
Is it possible to get this image redone without the components on it, so I can trace and isolate?
