[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
rngwn, does your manufacturer make SMD LEDs also? I think they might have some uses. :slight_smile:
Do you have a “before” pic of those to compare?
They do make SMD’s although I will need to do more research whether it make economical sense compared to the existing ones :wink:
There are very few options for CRI95+ SMD MP LEDs with reasonably priced worldwide shipping.
Actually I have found literally just one offering on Aliexpres, for 2835 LEDs. Everything else seems to have expensive shipping. :frowning:
I suspect I’m missing something and I spend merely an hour or so on the search. But anyway - this is not something widely and easily available for a reasonable price.
Are midpower leds often used on BLF? Before investing in them I would want to do an inquiry!
I’m planning on a midpower led solution for the BLF lantern, and a few people use them in flashlights with VirEnce boards, but that is probably not a high volume.
No I didn’t take a picture but the color it’s between the original Ikea tealight on the left and the 3400K on the right.
new batch of T/N:
flightless22 – LX104000114TH (2× 2300k)
staticx57 – UA121600087TH (1× 2300k)
*T/N number beginning with ‘U’ is non-trackable online. Contact local post office for status after 1-3 weeks.
Do those Ikea tealights have their own flicker circuits, or is it integrated in the stock LED, in which case you lose the flicker effect when swapping the emitter?
The LED tea lights I have are the latter type, so I’m keeping an eye out for something else.
What are those lights? Where to get them?
Want one.
I finally got the 2300K LEDs and tried them in my rechargeable tealight candles. I absolutely love it, it’s the closest I’ve been to a real candle light, and in a light holder of any kind it looks convincing.
From left: Original monochrome orange 3mm LED, 2300K LED and 3400K LED. Camera @5000K
Here they are with their included diffusers, looks pretty good. Can’t wait to solder all 12 of them and place them around the house.
I still use real candles on my living room table due to the cozyness and smell, but these are a lot safer to use unattended around the house, especially with cats around.
These Ikea lights have an integrated curcuit. I believe it’s these :
It’s just a tealight holder we’ve had for ages with Ikea tea lights inside :
Hey all, long time no see.
I would like to buy 100 pcs of 2300K 5mm LEDs.
I didn’t read the whole thread, so i’m not sure what you have in stock or if i should DM you, rngwm ?
Ah, okay !
You can PM me and choose the shipping option you desire (Pricing & fees in the OP).
If you want to make things easier for me, you can summarize the pricing in the PM for me.
(Tracked shipping is kinda pointless for Netherlands though, since it can’t really be tracked)
I hope you meant to say “10 in parallel to an AMC7135”. But why do you choose AMC7135 and PWM? :facepalm: The Arduino could be used to sense current over 3x sense resistor paths, precisely tuning a driving MOSFET VGS in each of them for accurate, PWM free linear current control.
I’ve read that’s not a good idea, but then I have not much clue about those things. I guess parallel is easier for the lower voltage needed?
Need to read about MOSFET circuits :weary: .
Ordered and paid. :+1:
No, that’s fine.
For 10 in series you need 32 29 Volts.
For 10 in parallel you only need 3.2 2.9 Volts, like from a single Li-Ion cell.
The AMC7135 will eat up a minimum of 150 mV.
In any case, driving leds in parallel could have some current sharing problems due to Vf differences between emitters. This can be minimized by binning leds with a multimeter, i.e. set them all extended over a table in a room with stable temperature for a little while first (acclimating emitters, they're sensitive to temperature) while laying a multimeter close, then use the multimeter to read and note down every emitter's Vf systematically at least once. Use the results to sort the emitters in Vf packs: 10 lowest, next 10, …, last and highest Vf 10-pack. This would minimize the above problem.
Well, as a word for caution, Vf disparity will be an issue.
The 3400k/5800k does have 0.1v higher Vf than 2300k.
