Sorry for s dumb question : how does one bookmark a post? Thanks
Converting Candela to Throw
Multiply the candela by 4, then square root it to get the throw in meters. Or square the throw in meters then divide by 4 to get the candela.
That is one heck of a writeup.
Thanks for taking the time to assemble the information and make it presentable.
At the bottom of the first post you can click subscribe to receive notifications of future posts or just save the web page in your favorites.
Thanks for this. Its very informative
This thread is definitely worth a bump.
Can a thread here be “stickied”??
Can a thread here be "stickied"??
Yes, but only Mr. Admin can do it.
If you want something stickied, you can ask him.
EDIT:
This thread has already been stickied.
^ Good to hear it. It has a very good explanation about the relativity of throw, spill, brightness, and temperature. And yeah, those zoomies are novelties for the most part.
thanks for taking the time to lay this all out for me Mr Newbie. I will go over it a few times in the next while. Thanks
Good article, you put a lot of work into this! Its very informative, thanksfully.
xie-xie
This is the flashlight bible in the making...
that bible has been written several times…
wle
Okay, evenif it was only bumped by a spambot, I’d hate if this got buried again. So… Bump.
BUMP - Very well done. Wish I found this 2 months ago when I first started researching flashlights!
Can always add:
It must list “tactical” in its description. If it’s not “tactical”, it’s garbage.
But these is almost always black. So don’t that make em’ almost all
ways...tactical?
I kept getting confused and mixed up between throw and candela numbers so did some research and wrote up what I found out. Also added some more explanation and a quick reference:
Hopefully this will make it easy to compare 2 lights when one’s specs says 100kcd and another says 600m.
Here’s some of the numbers to save you a click:
hm
interesting, thanx!
√(cd*4) also gives you FL1 throw in meters from candela numbers.
(Throw^2)/4 gives candela from FL1 throw.
