I will put you on the list for a possible second batch, will provide it soon in post #2, if there will be enough interests it could be realized.
Youāre absolutely right, thermal grease should be used very barely, always use as less as possible of it.
In this case we are taking about close a gap in the range of 0.1 to 0.2 mm as max. Between GND surface and copper plate is nearly no gap.
if there are 2 pieces left, please consider me.
Thanks,
olles!
Thermal pads have worse conductivity than pasteā¦but their big advantage is that they are solid. Paste may move around and leave you air gaps just where you donāt want it.
I think thatās only true when both are used properly. Since we are not using the paste properly I think we have to throw this whole statement out.
BTW, are these thermal pads like the ones used for cpuās? One use only, once separated you have to throw it away and use fresh pads. Plus you have to get the pad really hot in order for it to conform to the proper shape. Maybe newer style pads are designed differently?
My thermal pads being used in Audi A8 and Q7 and Q8 Bang & Olufssen amplifiers
Under the MOSFETs? I wonder why they didnāt use thermal paste like other amps.
Did you buy extra from them? Why do you have them? So many questions.
I donāt know where they put them in exactly.
Donāt know maybe easier to apply thermal pads in exact same amount than paste.
Didnāt bought them.
I work in an automotive electronics manufacturing company where we produce so many type of electronics for cars. B&O is one of our buyers. We make electronics also for Harman Kardon, Delphi, Valeo, Aptiv, Honda, Porsche, Mercedesā¦ But I donāt work at that area just asked collegues for thermal pads and they got me a few.
many devices use thermal pads now a days in production, its more consistent in application, and is easier and cleaner to work with.
in most cases that outweighs the minor differences in thermal conductivity, especially in production gear that has a large tolerance on the thermal characteristics.
i would wonder however if there would be manufacturing tolerances on this light that are so great that there would be measurable differences in the clearance between the copper sink and the chips themselves.
it would probably not be known until a large number of devices have had the copper sink in them.
What thermal paste did you use in your experiments man of ligjt? You obviously worked with heatsinks a lot, what paste (brand type) do you think would be best for this application? I could use professional opinion.
Iāve built plenty of PCs in the past and never had any issues with thermal transfer from CPU to heatsink, so I think Iāll just use thermal paste for mine. Just means Iāll need to get a new tube of Arctic Silver as the one I have must be well over ten years old, and I think the shelf life is probably a lot less than that.
For my tests I used Arctic MX-4, but only because I have a lot of it. Its a good one with relatively good thermal conductivity value of 8.5 W/mK, its not that budget.
Just for comparison, most common basic thermal grease/paste (white) have a value of 1-2 W/mK, but it will do the job also good enough.
So just use any kind you already have at home. And put only as much as necessary and as less as possible to the surfaces.
Iād suggest IC Diamond 24karat. Had a lot of pastes in the past and this one is the only that wonāt dry out in a month or two.
Also all components iāve used with this paste got noticably warm much faster than any other thermal solution.
or maybe itās just me... but i can recomend it 100%
Now made an update. removed copper and made a mix with thermal pads and grease. Where the gaps bigger I used silicone and at smaller or almost no gaps I used grease.
When removed yesterdayās work I saw that pads worked well but on the side colse to driver pcb I did not manage to tuck them deep enough.
Now made a better shaped thermal pad.
And for driver and side contact I used thermal grease.
Stuff needed:
And after assembly I also tucked in thermal pad slices to the side as many I could to heatsink the hell out of it:
And first run with 35 click ramp max setup (1367 lumens) Head temp was topped at 46Ā°C and stayed within 1-2Ā°C moving. You see the step down but the flashlight was tailstanding in a half open drawer in my desk so absolutely no air movement around it. In colder enviroment it can hold longer the output.
You can see there is absolutely no drop at start just a little stepping down caused by heating up for around 7-8 minutes. After that it stepped down because of the complete light was very warm. At end of test the light blinked out 48Ā°C (Temp reading calibrated at home so it is pretty accurate.)
So you need to make sure you use enough thermal transfer materials and I suggest using 0,5-1mm silicone thermal pads cutted shape on the 7135 top.
With factory ramp max setting which is above 2400 lumens you still have the drop.
I think you canāt do much more for this issue. Only one I can think of that removing one 7135 which is exactly the opposite side on the driver as MCU but that may cause a bump when ramping. I usually set ramp max to a level what a flashlight can hold for at least 5-6 minutes so I am ok with around 1300-1400 lumen setting where it works great. That output is plenty enough for daily use.
Played with Ramp max config. at 27 clicks ramp max you have no drop but at 25 clicks you have. I setted it to 35 clicks because 1360-70 lumens is enough for most tasks and it can handle for 7-8 minutes steady. If I ramp down a bit from ramp max I can use it for longer time.
Thanks for this results and your work
Thanks for this results and your work :+1:
Thanks for making the copper mod
Im intersted in a second batch, i thought i was in on the first one but i guess i wasnt clear in my comment that i lefr in this thread.
I let you mine, I will finally not get a MF01 mini.
