No Chinese power supplies sold from China are UL listed for the USA and have unbelievably cheap internal parts so I dont trust them. Use good quality ones like Dell, HP, Lenovo, etc. They’re cheap at the thrift stores.
I’m sure that you are right, but I’ve had that same experience with any Chinese seller on eBay whenever an issue arose; they will constantly delay (with extremely polite conversation, of course) until they are somehow able to close your claim without your permission and after the feedback window has closed (a ridiculous limitation, in my opinion).
Chinese sellers have learned how to play eBay’s policies against you and eBay seems silent on the matter. I’m sure that they use these same strategies on AliExpress. For anyone that has not experienced this, be warned that you will get responses the seller, at least for awhile, and they will be extremely nice to you, even claiming that they’ve personally looked into your shipment or re-shipment.
If something goes wrong with either eBay or AliExpress, simply demand an immediate refund and if that doesn’t happen, open a PayPal dispute. Do not concede to the seller’s request for mercy and understanding.
I fully admit that many AliExpress sellers are entirely unreliable and are often selling stuff so counterfeit that it doesn’t function at all. However, I’ve purchased hundreds of items from AliExpress and so far have never had any issues, so everyone’s mileage will vary. I try to buy only from established sellers or factory stores, but I’m sure that I will eventually get burned. That’s why I don’t buy $100 items from China.
In fact, I don’t buy anything from Asia through eBay anymore as I’ve been cheated too many times. I still use eBay, but only if the item is shipped from a U.S. address and when the delivery estimate is less than a week so that I know there’s domestic inventory and there should be plenty of time for resolution if issues do arise.
If eBay is my only option, then PayPal should still provide a refund when necessary, but even that process is not guaranteed to go in your favor .
I have been on eBay since 2000 and it’s changed a lot in 19 years. I was on before anyone knew you could order stuff directly from China, back when you could get a parts kit for a 1911 handgun or Glock slide and barrel or an automatic knife.
Buy carefully and you’ll probably be fine. Pay extra for shipping if offered.
Yep, it’s absolutely changed. I began buying and selling stuff like used music CD’s and film cameras on eBay in early ’98 and, as you’ll remember, the only option back then was “Auction”; none of this “Buy It Now” or “Best Offer” nonsense . IIRC, they didn’t register the eBay.com domain until the end of ’97 and my friend found it sometime that winter. I’m still the same 4-digit username as then, but I was forced to come up with something that wasn’t a standard name , so I’m “kank”, which was an inside joke between my friend and I at the time.
Since I don’t buy stuff from China via eBay and only did so a few times (and got burned most of those times), I largely use eBay like I always have. I don’t enjoy the auction process as much as back then, but I still buy used equipment that way sometimes.
OK - I think I’m getting closer to a purchase. The hot air gun Barkuti posted looks quite attractive and not excessively expensive. I’m just not sure if it will be a Step One or a Step One-and-a-Half purchase.
The TS100 looks nice, but it’s a bit more expensive and it looks like the tips are a bit longer between grip and work surface. My hands are not as steady as they once were, so the long shaft doesn’t really appeal to me.
The KSGER line looks nice. I really like using a standard PC power cord, but the comment about cheap Chinese power supplies has be questioning it.
The Quicko looks nice too. The DC in has me thinking that I can use some 2S battery packs I got for a portable HAM radio project, a laptop power brick, or, well, anything. I don’t like that it requires a particular power source, but for under $30 it’s hard to turn down.
For the purposes I listed in the first post, what tips should I be looking at? I know to look for lead solder. Any particular type of flux or solder paste? Tip cleaners?
I’ve had 3 tips, but not the T12. I am pretty sure they are all the exact same length. I think D24 is the one I have pictured. It’s the only one I ever use anymore. It has a large side for large jobs, and some nice small corners for small work.
I second getting good quality tips. I’ve been using the clones and the one that came with my Quicko is still working great. I heard to avoid the KSGER ones though…
Hmmm… so if the tip of the T12 models is about 4” past the insulated grip, and the TS100 tip is about 2.75” past the grip. That’s making me think the TS100 would be a more stable tool for detail work.
I like the longer tip since I can get into places without dealing with the handle getting in the way. Plus, only about the last 1.5 inches of the tip is hot enough to damage plastic (or fingers) if you’re butterfingers like I am.
If you choose your tip carefully, the longer reach is nice. I looked at the TS100 long and hard before I chose the Quicko based on the same performance, better tip selection, separate controller and handpiece (if I ever break it, replacement is cheap, plus there’s aftermarket ones) and the larger display with the encoder knob.
Either one are a huge upgrade over the fixed temp pencil.
…interesting visual…I think I’d do something other than solder if it came to that, but definitely go with a butane for that use! Also handy for low voltage outdoor lighting wires and the heat-shrink tubing.
I used to have one of those butane things. Until the attachment fell off while hot and burned my floor. That could have been my leg! Metal expands and softens just enough when red hot to loosen it’s grip to the butane part.
