WTS/GB: [4000k ARRIVED, Test Report's In] GT-FC40 (a.k.a. XHP70's flattop, 12v 40w sister) 95 CRI, Available in 4000k, 5000k
One host I have found is the Manta Ray C8.2 Host with 10mm reflector option can work.
Supposedly, the driver socket is 22mm, which is where 12v drivers are relatively easy to find.
rngwn, could these leds be ordered together with the 5mm leds from your other sale?
Yes, shipping cost will be the 5mm’s though (or from the item with higher shipping cost, in general).
Thank you! :+1: I will order in the next few days.
PP tracking info received.
Thx
What driver are you planning to use? I only find one or two 12V drivers.
Got my Paypal shipping info too. Thanks for the quick work.
I’m planning to try the 22mm 2.3A Convoy XHP35 boost driver. I ordered it but have not received it. The mod is probably a Yootoo SD2, because I think it fits the driver reasonably well (stock driver is 23mm). Not sure how the reflector will fit, it needs at least reaming to fit around the led.
I plan to use H2-C.
Still got a lot of A4 (4000k) bin left.
Anyone who want them can pay now. It will be quite a while until the 5000k version will happen…
Shipped
Djozz - 1pc A4
id30209 - 1pc A4
1stein - 2pc A4
808HI - 2pc A4
SKV89 - 3pc A4
Shirnask - 2pc A4
Scientist - 1pc A4
[C. Connell] - 2pc A4
KevinZA - 2pc A4
Skylight - 2pc A4
I took 1 pc for C8.2 build
81 pcs of A4 left as of now
I may order one along with more 5mm LEDs.
Early next year, some time.
Received my 3 today. They were well packaged in a sealed static bag like factory seal. Do you actually have a packager or did you order them prepackaged?
I’m waiting for my FT02 v2 and maybe thinking of swapping it in the Noctigon K1 XHP35 HI version. Should make for a very nice ultra HI CRI thrower.
Thanks for all your effort to bring us this emitter! Now just patiently waiting for Djozz’s test. :smiley:
That's why i order FT02v2 also LOL
I repackaged those myself. They are sold in a bulk tray.
What am I supposed to test?
I see you have a 4000K on order so thought you were planning to test one.
Of course I will do some spectrum testing, but if you refer to output/voltage, I was not planning on that because I expect it not much different from the 5000K one.
I’m waiting on a XHP35 driver, I was thinking of first do the mod and then check the tint.
I had been wanting to upgrade my Jaxman Z1 for a while and this emitter seemed like a good opportunity to do it. I had a Kiriba-ru Cu pill and when the H2-C driver arrived the other day I jumped on it
Now I don’t have to go through the H-M-L-strobe-SOS modes it came with. And as a bonus when zoomed in I don’t have just four panels but 16!. One thing that is visible when zoomed in is that the individual panels are not uniformly colored. It’s a little hard to tell in this image because I can’t bring the emitter surface into complete focus, but some of them are yellower than others (upper left) and there is a dark spot lower right of center.
It doesn’t really affect the beam when zoomed out (flood mode) and I will typically use more flood mode than zoom mode. I just wanted to show you guys an example of what you may get. So now I have improved modes and high CRI in my Z1! Thanks rngwn.
An additional note, I’m not sure what driver they sent me. It has four modes that correspond to very low, low, medium and high, but double clicking goes to turbo and triple clicking goes to strobe, modes not listed for the H2-C description at the place I ordered it. It’s drawing over 4A on turbo but I only have a Fluke meter to do tail measurements so I’m probably measuring too low.
I’m surprised at the huge difference in tint within the same emitter. I was thinking of modding a Cometa with copper pill but you just saved me the trouble. Thanks for letting us know.
Finally put one in a suitable host. The manta ray C8.2 w/ 10mm hole.
https://www.reddit.com/r/flashlight/comments/ejt0qh/nld_manta_ray_c82_w_selfsourced_4000k_95cri/
Wow you found a perfect fit spacer too. Where did you get the spacer?
