Neal didnt respond me either after many days still no reply to question, was kinda interested getting this before holidays and all but if cant get answer then i didnt chose to buy someting else not from him sadly…
That’s what I bought for it. They are rated 35A and they are known to actually achieve that number. There’s also the Samsung 30T but I like to always use the largest cell the light can handle. They are a bit pricey though, I just paid $9.99 plus $5.00 s&h from vapewild.
Edit: Not sure if this light can take anything other than a 26650, I just assumed as most do.
Updating post #386
My NI40/SBT90.2 of the first batch stock “is not ship because of the shortage”, order #8378.
In mi account that order continues appearing FULFILLED.
The tracking number that appears corresponds to the previous order (received).
Two last PM sent to Neal, on December 6 and 12, with no response.
Neal was in BLF 4 hours ago but did not deign to respond…nor correct the order status in my account.
Summarizing…
Without any change in the situation.
Neal continues in radio silence.
For now I have lost interest in this light and it is on the shelf until work is done on it.
I hike every night with my friend Randy and his Dog Max. Randy and I both love Turbo when on the hiking trails. I get enjoyment for 2 minutes of Turbo and then it is constantly stepping back up to Turbo every 60 to 90 seconds.It becomes Very annoying.
My Mateminco MT35[FT03] XHP50.2 NW has Narsil. I disabled the step down. The light never got too hot even in August.
When my NI40 is able to do that, I will enjoy it more than the MT35 because I like all the other aspects of the light.
I had filled out the form and submitted it, expected a notification when the lights would be ready again. Never happened, which is ok because I too have had so much problem with Neal getting it done that I no longer care to make a purchase if he’s involved. Sad but true.
So I’ll be looking for the 90.2 and will build my own Stalker if/when I find the emitter. In the meantime, the one I have here works pretty well with the original SBT-90. (built a driver for it, hated the UI)
Ran it 10 minutes on turbo tonight, changed battery and repeated.Not even close to hot. Temperature was 25F/-4C.
In the warm weather I can do the same. I have a high tolerance to heat. With this light by the time I pass the 5 or 6 minute mark the battery is certainly weakening along with the output, resulting in less heat.
I do not know. I do not know how to work on these lights like a lot of you. A member on here is going to make positive changes for me. Completely eliminating step down,new driver, bypass springs ect.
