I received my SP 33 V3 yesterday after a long wait.
When I first took it out the package I was wondering how heavy the flashlight was. Then I unscrewed the tailcap just to find a Sofirn labeled 26650 cell in there. The black one with 5500mAh printed on. (Flashlight ordered on Banggood)
The looks of the flashlight are better to me in person than on the pictures. Looks and feels good (very good grip)!
The beam is not pleasing to be honest - but it’s okay. Brightness is fine, probably under 3500lm as stated before. U.I. is super simple and the switch feels good.
I tested the Sofirn 26650 cell and it seems to be a fine one.
Internal resistance about 0,23mOhm
Capacity test showed me 5430mAh
Well filed a dispute today. Bought from ali store and my messages were unanswered for 3 weeks. Status was shipment cancelled. Tried contacting Sofirn via many ways. Got two answers saying that they dont run the aliexpress store and thats it. I never got my SP33v3. Was really looking forward to this light. But no I will probably never spend a dime to Sofirns direction. Atrocious customer service!
Found a review of the SP33 v2.0 on Zeroair and shocked at how VERY efficient it is. The driver efficiency is on the level of Olight, Fenix, Nitecore, and Zebralight! Wow
Sofirn should continue to sell v2.0 alongside v3.0 because some people would prefer the super efficient driver and perfect regulation.
Have a SP33v2, swapped emitter w/ 5000ºK (damaged led in transit). Best budget light for sustained high. Great UI - low/med/high w/double click for temporary turbo. Long press from off for Moonlight (~ 10 lumens), just right for a evening walk.
I lose mine at 3.70 volts. Dirty connections can have an effect. Boost drivers need as much voltage as possible so you want to make sure the circuits are clean with no extra resistance.
You have the driver ring, both battery tube ends, the tail cap to battery tube area, pop the spring out and clean the pocket, clean the spring, clean the battery ends. I think that’s all.
Have you tried different batteries? I’m not certain, but battery voltage sag might play a part. I use the Shockli 5500mah as well as Aspire 4300. The Shockli seems to work better since the amp draw is not that big at 6A.
I have not had a reason to bypass my springs, but that’s something you might consider. It might give you longer cumulative Turbo runtime.
Although you might already tried it. I’ve had so many lights that loses turbo shortly or immediately and it is fixed after washing the tube and head with detergent and cleaning the head spring or contact with rubbing alcohol. I’ve had many lights including Thrunites that had black grime on contacts that require much rubbing with finger nail to remove. Fixes turbo problems and low output almost every time.
So, the big question is, is the V3 at $30 a better light than the V2 at $20? Even if money wasn’t part of the equation, is the V3 really better than the V2?
Depends on how much you value max output and USB-C recharge. For me USB-C recharge is important in a muggle friendly light like this. However, I much prefer the V2 boost driver for its excellent regulation and efficiency making it more suitable as a tool. I wish Sofirn makes a USB-C version of the V2.
Your logic convinced me to order the V2. While the max output is better on the V3, it doesn’t seem to live up to its numbers (as stated here), making the difference to the V2 not as dramatic. USB charging isn’t all that important for me, but steady and constant output is. I just ordered the V2 on Sofirn’s site with battery and charger for $20.70.
Received mine today. I love it so much…It makes the tint on my EC01 look good The bezel, reflector, beam pattern and charging port cover are identical to the EC01 but the tint is cooler and a bit greener…Seems like sofirn also make the EC01. Why didn’t they just stick with the same LED as the EC01 5000k? The only good think about the cool LED is the slightly less noticeable tint shift. The design and build quality is nice but I dont like the fact it has a FET driver whereas the older version was constant current. I definitely would have preferred anduril with 5x 7135 and a warmer tint. Might end up selling it. Not sure though. It’s for my family so they probably won’t mind the tint. Oh yh and one last thing. The LED indicator seems almost useless. It stays off when the light off and comes on for a few seconds when you turn the light…I guess its just there to serve as a low battery warning and charging indicator. They should’ve just made it stay on so you can find it in the dark…I know I’ve said a lot of negative things about it but it’s still a good light. Just not what I’m looking for.
Sofirn…if you’re reading this could you make a V4 with a better tint, regulated modes up to 1000lm and a way to permanently disable turbo. Like maybe 5 short clicks and one long. Something that someone can’t do by accident. If you do the above this could be the perfect muggle light.
My quick impressions of the SP33v3 after spending some time with it. One note, I ordered with the 26650 battery but it did not come with a battery.
Pros:
Build quality. It feels solid and looks good. The machining and anodizing are very pleasing.
UI. It’s simple and intuitive. I really like it a lot. The moonlight and turbo (and strobe…) modes being hidden as well as instantly accessible from off make it very versatile. Good usable mode spacing too for the stepped mode. Plus of course there is ramping mode.
Cons:
Beam colors. My first reaction turning it on for the first time: “Wow, that’s ugly!” It has a hotspot that is white enough, but there is a VERY noticeable green/yellow ring around it, which then turns to a noticeably blue spill. At close range it is very distracting because the same object will look multicolored! Truly the worst part of this light. The colors are so bad, I don’t even notice color temperature, CRI, or any other typical concern. At larger distances or for general lighting, it is ok… ish.
The switch is difficult to find in the dark or by feel. It always takes me time to find it, and the easiest way is to feel for the bump of the charging port and know that the switch is 180 degrees away.
Overall, I think it’s a great flashlight and it has a ton of brightness. I’ve been using it with only 18650 batteries that are not high drain, so I imagine it is capable of even more brightness than what I’ve seen. Very abundant on that front.
A minor note is that the cuts for the “fins” of the heatsink are slightly sharp, unlike the smoothness of all other edges. Not a huge deal, but I do notice it and wish they were deburred slightly better.
Generally, the SP33 feels really good in the hand. The 26650 tube is a nice size and every time I hold it, I feel happy about the construction quality.
The USB charging is a feature I appreciate a lot as well. I don’t know what the charge current is but by comparing with the SP40 which is known to charge at ~1A, I’d say the SP33v3 charges at a higher current since it is a bit faster. That also means it seems to charge the same batteries slightly less than the SP40’s built-in charger.
With it plugged in to a charger, there is a 1.8 mA parasitic drain. That goes down to ~26-28 uA with the cable unplugged.
Welcome to the world of the Cree XHP50.2 and XHP70.2. The older 50 and 70 had a much nicer looking beam with no yellow corona, but they also tend to produce a donut hole beam pattern (OP reflectors needed) and the max output was lower. I will say you tend to get used to the corona over time. Maybe we will get better leds in the future.
I think the very new Luminus SST-70 might make a good replacement for the 6v 50.2. Hopefully we can buy them soon. It should make a nice replacement for the version 2 light. I dont know of a good led for this version 3 since it’s 3v.
