Review - Imalent RT70 XHP 70.2 5,500 Lumen Monster!!!
40 posts / 0 new
hIKARInoob
hIKARInoob's picture
Last seen: 1 hour 13 min ago
I assume batteries are fully charged. Maybe some batteries’ protection kicked in because voltage is too low. You could check individual battery voltage just to be sure. But there is unfortunately also the possibility that the light is faulty.
gaetano76
i HOPE THAT LIGHT IS NOT FAULTY ….I BUY IT IN SPAIN !!!I AM TRYING TO DISCHARGE AND CHARGE THE BATTERIES THE SECOND TIME !!!
Lightbringer
Lightbringer's picture
Last seen: 2 hours 5 min ago
Blinking before turning off sounds like LVP kicking in.
You using flat-top cells or button-top cells?
How many are loaded? All 4?
gaetano76
ORIGINAL BATTERIES IMALENT THAT ARE BUTTON TOP !I CHARGE IT WITH NITECORE UM4 CHARGER NOT WITH THE CHARGER ORIGINAL MAGNETIC ….BUT IT SEEMS THAT WHEN I AM INSIDE HOME TURBO WORK ,BUT OUTSIDE IT TURN OFF
SKV89
Last seen: 19 min 59 sec ago
Poor connection? Cleaning contacts on both the light and batteries with rubbing alcohol works miracles in many cases when I experience turbo issues.
hIKARInoob
+1 Thumbs Up Beer
gaetano76
hIKARInoob wrote:
+1 Thumbs Up Beer
I CAN TRY TO CLEAN WITH ALCOHOL ,I DON’T UNDERSTAND WHY ONLY TURBO MODE GET PROBLEM , INSTEAD IN THE 3 4 MODE NO PROBLEM , I ‘D LIKE TO TRY OTHER BATTERIES !!!
gaetano76
Can i have a photo of the batteries that used for the rewiev of this flashlight?
hIKARInoob
He used button top Samsung 30Q cells. You can get them for example at NKON: https://www.nkon.nl/rechargeable/li-ion/18650-size/samsung-inr-18650-30q...
