I bought some sapphire lenses on aliexpress, as far as I can check it, they are legit. This store has a good collection. Check if they are flat and the correct thickness, because they are sold as watch christals, some are convex.
thanks for the link and suggestions to avoid domed lenses
I have not actually found any sapphire listings in the 18mm diameter range (intended for original RRT-01), yet
I’m not around a lot anymore, made a lovely career change in my 50’s that’s all encompassing at this point.
Try this fellow for sapphire, if he doesn’t have what you need, he will more than likely recommend a source. I just used his lenses for a NiteCore mod last year, very happy. Be cautious of crystal thickness and also of replacements with rounded edges, you made need o-ring changes, depending on the torch. .005 matters
and thanks for the 0.13 mm tolerance ( 0.005) relevance, advance warning about rounded edges, and potential replacement O ring awareness
all very helpful
I shared that suggestion with someone, but it did not work out as expected… I dont know why, I have not tried the Crelant myself…
they reported
“Crelant 7G3CS arrived today. It does NOT fit the JetBeam RRT-01 as I had hoped. I put an 18650 battery in it and it has two speeds, 1226 lumens and 350 lumens … Note that the Crelant 7G3CS tube threads are slightly different than the RRT-01 and will not engage in the JetBeam’s head”
any solution I can pass on would be appreciated
Edit
it is possible the mismatch Im hearing about was between the head of a NEW 2019 RRT-01 and the Crelant. imo Archibald Tuttle knows what hes talking about. In no way do I doubt his recommendation that a Crelant 18650 tube fits an ORIGINAL RRT-01
This thread really needs to become a sticky. Sincere thanks to everyone who contributed.
Late last year, I lost my Nitecore D10 to American Airlines, and began using a long stored JB TCR1 as EDC.
The adjustment ring on the TCR1 was just pure trash. I almost treated it as such, and nearly binned it.
Some BLF knowledge and some Nyogel ( it had no grease, none) turned the TCR1 into a world class flashlight.
It’s hard, for me, to go back to another EDC interface after using the dimmer type dial.
A stock BLF Q8, modded Thrunite TH20 & modded JB TCR1 are a extremely versatile trio.
Very sorry for your loss of a D10, really happy for you to have a TCR-1 to enjoy.
When I got my TCR-1 the dial was not smooth, it took a lot of massage and lubricant to get it to feel buttery smooth (without disassembly).
Some of my RRT-01 were also not smooth, but after disassembly and lubricating with Nyogel 767a they became a joy to use.
The feel of a smooth the ring with no grittyness, nor excessively easy to turn, transforms the experience from apparent low quality, to feeling like a High Quality instrument.
The convenience of operation of the Jetbeam Rotaries have spoiled me. I still use a couple clicky lights (one set to 0.02 lumens for bathroom visits, and one that turns on at 20 lumens for brief illumination needs on my desk, but I have greatly slowed my accumulation of lights with buttons.
For me, the RRT-01 has been a game changer… not sure why, but I seem to have accumulated more than one… lol!
I agree this thread is full of a wealth of info. Thanks to all who participate and contribute.
Thanks, and more thanks, you have helped make this a one stop shop for JB rotary info. This is a easy, intuitive, and depending on one’s age, very familiar UI.
I spent a lot of years with the D10, but perhaps the loss was for the best. It wasn’t hard to overshoot a desired level with the D10 , due to ramping speed. And at it’s lowest level, on a minimal battery charge, the PWM was easily seen.
The clip was broken off of this TCR1, I still have to deal with drilling out the sheared machine screws and tapping new threads. I’ve got a original, McGizmo clip to fit. Then it’s on to led selection. I like so many different emitters and kelvins, it’s gonna be hard to find a middle of the road emitter and matching reflector.
Such a cool design, cant help but think of Spinal Tap
they work with the 219b options I enjoy
my personal general purpose grail is the sw45k and that link also lists a source for those
along with other parts useful in a TCR-1, including an XP compatible mcpcb, the driver that has a Strobe option, and a shorter clip. (though I respect your choice of a McGizmo option)
(I was not in USA in my youth, and missed the Spinal Tap experience. Thanks for supporting and contributing to this Stepless Rotary conversation. )
Thanks Jon, traveling due to work right now, layovers give me time to go over all the options. It is a really useful design, from theater seating to menu reading, poorly lit parking garages,etc.
And it carries easily, even without a clip. That and the current crop of 18350 is easily more capable than the 14500 cells I was using before. Although I would always like to have a option of running AA in a pinch. Looking through older google images, it looks like it may lego with the the discontinued JB “DD” series (digital display). I actually have a AA version of that light. Curious as heck now if that light body will actually work on the TCR1 head, without exposed threads and o-ring.I won’t know till I return home this weekend.
Still working through jet lag and fatique. Got the broken pocket clip screws sorted and retapped.
Also tried the JB DDA10 and it is confirmed. Maybe a little homely, but fully seated, and fully functional. Threads seat and o-ring is completely engaged.
I tend to collect and keep red led display items, such as old Texas Instruments calculators and TIF Instruments digital ammeters.
Never have imagined a future Lego from this DDA10.
