I ordered one on Dec 12 and it just shipped. Hope I won't be disappointed, I originally cancelled my first order when I saw the FT03 with SBT90.2 since I couldn't decide between the two and then ordered again -.- I'm still unsure if I made the right decision... guess I'll find out once reviewers get their hands on the FT03.
Wondering if anyone can talk a bit about the driver, especially whether or not there's a reprogrammable microcontroller on it that could be reprogrammed with custom firmware?
I agree, if one is actually looking for a thrower as an actual tool to use - in which case there probably would be size and runtime constraints etc... whereas personally, I'm just looking for a cool light to add to my (admittedly small) collection. So for me it's mostly how enjoyable the light is for an enthusiast vs. how much it costs. And I just can't decide which light I find cooler, while acknowledging that they're technically not in the exact same category :D
(at which point of course you could say "well, why not get both then", but money is still a constraint for me unfortunately)
I ordered on October 21, from the stock of the first batchā¦
In the āFULFILLEDā order, the tracking number has not changed, the one that appears corresponds to the previous order (FW3 Ti + Cu, received).
My patience is over.
Another PM sent to Neal, will be the last.
I gave 48 hours to ship or refund. If he does not send it or makes the refund in 48 hours I will start the process in Paypal.
He called it a simple mod. I call it a Game changer and a Light āSaverāā¦.without it I would have sold it. That crappy driver had to go.
I have a link to the driver he used in my post #443. A FET-22mm from Mt. Electronics. I chose CUSTOM Firmware-3%/50%/100%-Mode Memory and with NO STEP DOWN[NO Turbo Timer]. That is the sole purpose of getting it done.
It is nice to turn it on MAX and let the battery/output deplete naturally without that frequent and annoying step down.
Tonight was 40F/4C.I used my Aspire 26650 4300mAh batteries and I was able to run it for 10 straight minutes on max without the handle getting too hot.Battery change was after 10 minutes where the voltage was around 3.64V. I know that from my run time tests. I did that Three consecutive times. The only break the light got was from battery changes and the last 30 seconds before I switched batteries I used it on 3% to let it cool a bit.
I have always liked my hand to be the judge in terms of when I dial it down. Step Downs are for amateurs!
I have purchased three of these, and just like Baron, I hate the driver. I sold one already and I havenāt used the other two since day 1. Maybe itās time to change out the driver as well.
Mine arrived yesterday. I was very pleased to see they actually now put "Stalker 2020" on it instead of 2019. Cool! I have to say it looks stunning, the design is very much to my taste, the SS bezel gives it a very nice touch. There's a tiny smear on the LED (not directly over the chip though, it's off to the side), probably a bit of flux. It's translucent tho, nothing that bothers me.
I do not have any switch issues, can cycle modes perfectly fine (maybe they changed something for this batch? IDK). The firmware is simple but acceptable imo. The mode spacing is a bit weird, with a big jump from mode one (can't call that a "moon mode" at all) to mode two, then only little difference from two to three and four. Big jump again to Turbo for me (using a Golisi 26650). The light heats up quickly on turbo as expected, it reached 45-50Ā°C rather quickly and then slowly crept up to around 60 in a test I just did with a full battery. I'd call the step down practical. It's a turbo mode after all, it's meant for short bursts, else it'd just be a regular mode.
Definitely Awesome! It is very enjoyable to use now.Probably have about Two plus months of using it on max continuously.
When late spring and summer come I know I will only be able to use it on max 2, 3 maybe 4 minutes. At least my hand will determine when I step it down instead of that annoying stock driver.
