However, as I mentioned a few times before, a lot of it comes down to personal fitment/comfort. Just because they fit 10 other people great is no guarantee that they will fit you. If your ears don’t happen to jive particularly well with a given earphone (not a good seal), then forget about good bass.
Sometimes you have to go through a dozen different earphones until you find ones that fit you well. Thank Amazon for a good return policy.
Exactly, if it were about need we could all just get a set of 4 or 6 of the AA lights, and maybe one of the bigger lights for a total of about $30 and be done with it.
I would also have about 90% fewer tools than I do now Watch what people do in 3rd world countries with only the most basic tools
Yes, even-though the name sounds funny this is one of the better brands in the world of Chinese jump-starters… I have one, not this model and its pretty good at what it does. Mine is many years old and still holds good charge and was one of the first one to support quick charge input and output.
I also have a Gooloo jump starter. I have used it about 5 times with different people. It always works and the battery last a very long time. I might get another one for my wife.
Thanks!
Just snagged 1, as my lawn mower needed a jump last weekend, which involved a 2 vehicle juggle, and then tearing apart 2 totes to find my cables.
Sure, but I think there is more to it. I think the car jumpers have additional capacitors in order to help deliver huge amounts of current to help crank the engine. Your typical power bank can’t do that.
i took apart a $50 broken one, no caps, just 3 flat prismatic li iron phosphate cells
caps that size would not provide more than .1 sec of what a starter needs
the batteries have to do all the work
i was just saying, the power bank function is a side benefit of these things
Thanks! Just ordered one. Truck battery is 4 years old but struggles below 0 degrees F lately. Do need to replace it. Have older batteries on tenders which sometimes need help in very cold weather. Will report back when it arrives and gets used. Others I was considering are twice as much. Audew is what I was looking at. Amazon.com
