ReyLight copper pineapple mini, AAA/10440 flashlight, Nichia 219B 4500K R9080 high CRI LED
Quick measurement in bathroom:
D4V2 SST-20@3000K, 100 lm equal 6 lx
Olight S1R II 1000 lm equal 69 lx
Pineapple maximum = 10 lx, equals between 145 and 167 lm with the above standards.
all measurements done with Benetech GM1020.
Edit: I still might be completely wrong!
I kept it default, so whatever mode it came from the factory as.
Got mine as well today, nice surprise for it to arrive so quickly. Thanks Reylight!
Try changing modes. Lexel’s Bistro drivers i’ve got had to be programmed otherwise they deliver only 50%.
not reprogrammed but correct group should be chosen from options menu
I lost the manual so don’t know how to change modes. I wish Rey would post the manual on his website.
Eight half-clicks, light blinks once, then flickers. Now do one half-click and you’re in first mode group.
Reverse clicky switch. Full click to turn on or off, half click (tap) to cycle modes.
Program: When the light is on, quickly half click 8+ times.
  1. Select different modes groups. (1-4 groups)
  2. Turn on or off memory function. (Default is off)
  3. Turn off or on moonlight mode. (Default is on)
  4. Mode order. L-M-H → H-M-L (ascending or descending)
  5. Reset.
    Shortcuts: Quick double clicks = turbo
    Modes groups #1-4.
  6. moon-2-20-100%
  7. moon-10-40-100%
  8. moon-2-10-50%
  9. moon-50-100%-strobe-SOS
this light sure has tricky modes… way too many imo, why ? aaa light should be easy to use not so many different modes etc…
It’s only 4 modes…it could have done without #4 imo, but someone so where wants stroby… The crazy person…
I noticed the trit is glued, but not covered by the glue. Is it advisable to apply some extra UV curing glue to completely cover the vial? It seems quite fragile.
Edit: I did, and I’m happy I did :smiley: :+1: Looks much better.
I just received mine and did a very rough test with freshly charged AAA batteries. Using the Android ceilingbouce app I get 8 lux/lumen for the Reylight and 9 for my Prometheus Beta QRv2.
Switch to a freshly charged Efest 10440 and I get 28 lux/lumen, although it does drop quite quickly. This seems promising in regard to the claimed performance figures.
Another measurement: Tip CRI 2017, 240 lm, 12 lx. That would make the Pineapple Mini (10 lx in bathroom) 200 lm. Still not there.
Yep I tried all the modes. Tried everything and no change to the turbo output with lithium ion
Not even in mode 3?
Mode 3 only goes up to 50%. Besides double clicking suppose to bring it to turbo.
Just got mine today . First Reylight for me . I got 240 lms out of mine from a fresh charge PKcell . 204 from the battery that came with it . It’s a nice little light . Got the green trit. 13 days from order to arrival. I think that’s the best I have ever had . Thanks Rey !
Lost the manual? There was no manual. But the plastic case was nice!
I love the style and emitter on this light but the programming UI is awkward and the instructions from the website are unclear. After you half click 8 times and it goes into blinky mode, are the numbered items the number of half clicks required? i.e. 3 half clicks to toggle moonlight mode?
Can someone post real instructions for this light?
No. The light blinks out the menu number, then flickers. While it flickers, you half-press the button for e.g. the mode number. Wait until flicker ends and switch the light of. Done.
To get into Moon-Menu, wait for the light to flash three times and subsequent flickering. Now do a half-press or two (unfortunately, that is not clear to me, but you can try).
Ok?
Fits nicely the GITD sealing ring :+1: .
Got it. Nice light. Definitely rosy tint. Trit neat and tidy. Thanks Rey!
Real max lumens? - you all sort it out and let me know. I am happy either way.
