Just got mine today . First Reylight for me . I got 240 lms out of mine from a fresh charge PKcell . 204 from the battery that came with it . It’s a nice little light . Got the green trit. 13 days from order to arrival. I think that’s the best I have ever had . Thanks Rey !
Lost the manual? There was no manual. But the plastic case was nice!
I love the style and emitter on this light but the programming UI is awkward and the instructions from the website are unclear. After you half click 8 times and it goes into blinky mode, are the numbered items the number of half clicks required? i.e. 3 half clicks to toggle moonlight mode?
Can someone post real instructions for this light?
No. The light blinks out the menu number, then flickers. While it flickers, you half-press the button for e.g. the mode number. Wait until flicker ends and switch the light of. Done.
To get into Moon-Menu, wait for the light to flash three times and subsequent flickering. Now do a half-press or two (unfortunately, that is not clear to me, but you can try).
Mine appears to have been sitting in Shenzhen with the airline carrier since the 15th (ordered on the 9th). Does the CNY affects air travel too? Maybe I just missed the window…
the whole country is shut down more or less during their holidays, its crazy but thats how it works there dont expect any movement until early next month.
Mine got here relatively quickly (upstate NY) , about two weeks. Great looking light but it’s malfunctioning. Won’t come on unless I unscrew the head a few turns, then works for a bit then goes out again. Emailed Rey but like many in his country it’s vacation time. Anyone else experience this or any ideas on a fix?
After about two minutes on 10% mode the light turned off, leaving me in the dark. I tried an AAA but it won’t came on. Re-inserted the LiIon and it was alive again. Cannot reproduce it. It didn’t get hot, there were no mechanical impacts. I can slighty unscrew the head and retighten it, shaking the light, whatever, it works continuously.
I will take it apart if there’s time. For now, it is suspended from its EDC duties.
I don’t have any li-ion in this size, only AAA Eneloop and AAA alkaline. They both exhibit the same behavior...by the way...shouldn’t there be an O-Ring between the lens and the reflector?
