CRX CuTi R8 Osram KW CSLPM1.TG
17 posts / 0 new
CRX
CRX's picture
CRX CuTi R8 Osram KW CSLPM1.TG 5400K - Convay·MK - 18350 - Rv Clicky Tail Sw - 1080lm.CRX CuTi R8 Osram KW CSLPM1.TG 5400K - Convay·MK - 18350 - Rv Clicky Tail Sw - 1080lm.
Hand made with files & hacksaws
Grade 9 (Ti-3Al-2.5V) Titanium & copper body
Osram KW CSLPM1.TG 5400K emitter
Copper DTP MCPCB
20mm OP reflector
20mm x 1.5mm ARC glass
Aluminium pill
Convay·MK variable 3 mode driver
Carbon fibre bezel & body inserts
Electro-anodized titanium
Magnetic tail
Reverse clicky tail switch with 6mm x 1.5mm red tritium vial
Length - 76mm
Width - 24mm
Weight - 77g (with 18350 cell)
Max - 1080lm OTF (6A)
30s - 920lm
60s - 865lm
Mode 1 - 405lm (1.4A)
Mode 2 - 1080lm (6A)
Mode 3 - 27lm (0.05A)
CRX CuTi R8 runtimes:
CRX CuTi R8runtimes:
Not too bad regulated output though no sign of LVP, the light just dimmed, cell removed at 2.7v.
So I thought I would try the variable SST-40 Convoy driver along with the Osram KW CSLPM1.TG 5400K emitter with this build.
I used an aluminium pill which was not the best choice with the thin titanium body, forgot about that.
The light was originally meant to just be plain titanium but it produced far too much heat as the convoy driver has no thermal monitoring, forgot about that too Big Smile
So I had to add some more mass to the light somehow and that took the form of eight copper rings which helps a bit.
The light can run hand held comfortably at 1.4A current which gives around 400lm.
Turbo can run for around a minute before it needs kicked down to prevent meltdown on a full cell but can go longer with some depletion later on.
Quite a nice simple driver.
The first two modes of the driver are current variable via a ramping system and the modes are accessed like this:
Mode 1 - Single click On.
Mode 2 - Single click On, Double half press
Mode 3 - Single click On, Triple half press
I have it set up like this at the moment:
Mode 2 - 1080lm (6A) - 30s - 920lm, 60s - 865lm
Lights are like children, once you've created them, you can name them whatever you want  LOL Thumbs Up
Edited by: CRX on 02/24/2020 - 13:50
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 16 hours ago
So this child is your Japanese offspring LOL
CRX
CRX's picture
Yes, GoRingu’s brother LOL
pinkpanda3310
Lol, I knew the title rang a bell Big Smile
No matter how many times I see it I’m still amazed you make these things with hand tools Crown Star
CRX
CRX's picture
Smile Thumbs Up
Mike C
Mike C's picture
Last seen: 6 hours 29 min ago
Gorgeous! I don’t think I’ve ever used that word to describe a light… I wonder how you keep coming up with these designs.
MtnDon
MtnDon's picture
Last seen: 40 min 30 sec ago
I especially like (covet) the twist/lock slot mechanism. Very nicely done. Thumbs Up
CRX
CRX's picture
I just start off with a rough idea and see how it progresses while it’s coming together, like this one – turned out completely different to how I intended it to be because I didn’t factor in a few things.
It helps having lots of various bits & pieces that I’m always picking up and trying to match up to make stuff Big Smile
Getting short on nice drivers now though Innocent
CRX
CRX's picture
Thanks. An Old Lumen method too.
Yeah it’s an option I like as I cant make threads. I could have installed stoppers and an o-ring for waterproofing too but decided not to, there’s an o-ring in the head.
Mike C
Mike C's picture
I here ya! It’s moving forward…. been working rather intensively on then lately. The coding is rather quick, it’s the testing takes time. Had a few rather nasty bugs to weed out.
CRX
CRX's picture
Wink Thumbs Up
Just looking forward to it Big Smile
Slayer1
Slayer1's picture
Last seen: 1 hour 33 min ago
Awesome build! Thumbs Up Beer
JaredM
JaredM's picture
Last seen: 1 hour 26 min ago
Always impressed with your builds CRX. Great work!!
How’s the tint on this emitter?
CRX
CRX's picture
I think it's between 2B & 3A though the KD description has it at Cx = 0.32, Cy = 0.33, around 1D, very slight green tint to it.
Sorry for the crappy pic.
JaredM
JaredM's picture
Looks very reasonable! I bet it actually is pretty close to D55.. Thank you!
NeutralFan
NeutralFan's picture
Last seen: 15 hours 36 min ago
Another cool looking tail switch to compliment another awesome flashlight! I have files and hacksaws, but not the magic touch CRX has.
I’d rather use my flashlight around the house than turn on the lights.
Lothar
Lothar's picture
Last seen: 1 week 2 hours ago
Beautiful! Beer
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
