Unless your making sure cells are the same voltage its risky parallel charging, you will increase the IR of the batteries that will affect the end voltage of the cells and the amount power the cell can give over time as the cells fight each other with sudden discharging and charging to self balance when you connect them.
If you series balance with a cheap clone charger yes it might be out 0.04 volt out per cell, but there is a good chance in you parallel you still will be out around 0.04 to 0.06 volt due the inaccurate calibration of the main charge leads.
I series balance charge 2 x 2400 2 x 2600 and 2 x 3100 mAh cells all at once with in 0.001 volt and still can charge them a lot faster then a xtar wp 2 charger 2 at a time thats with in 0.03 volt and charge them faster then an imax clone.
It also depends on your charger the cheap clones can be slower to balance charge then the more bigger $$$ chargers, but you still will save time if you charge more then one or two at a time. IMHO lower amp charges in series your batteries will last longer then higher amp charges in parallel some thing Ive notice over years of RC.
I may have changed these settings when I was screwing around with the charger but I didn’t think I went into the NiMH settings. It looks like the default setting for NiMH discharge is .1A and down to .1V, seems to low on both counts. What should these values be? I must have changed them at some point.
Any reason why no recommendation to set discharge final NiMH voltage to Auto? I would think that would be safer for new owners of B6 (N.O.O.B) rather than discharge too deep.
For many reason's slow charging the batteries will last longer, the internal resistance with stay lower for longer, the battery will be able to give more current for longer.
As an RC freak we always fast charge and hammer our batteries with high charge rates (C) and high discharge rates, but if you are not in a rush a lower charge rate IMHO is always best.
Nimh should never get hot while charging.
I charge 4 x AAA in series @ 0.2 amp, 2 x AA in series @ 0.5 amp, 8 x AA in series @ 0.5 amp, 4 x D in series @ 1 amp.
My AA nimh have a recommended charge of 0.65 amps Ive been using them for over 5 years for RC radios, GPS, xbox 360 controllers and a digital camera and they are still going strong, But a set i use for my RC radio i used to fast charge at 1 to 1.5 amps are dead.
I also charge my 18650's like this in series 2 x 18650 @ 0.5 amp, 3 x 18650 @ 0.5 amp, 6 x 18650 @ 0.5 amps, 3 x 26650 @ 1 amp. Single 1 x 18650 @ 0.5 amp or 1 x 26650 @ 1 amp with my hobby charger.
I do have some batteries with the Maxim charge rate of 1C 3.1 amps but i still charge them @ 0.5 amps, i have trustfire flames 12 months old still going strong.
Because you will get a deeper charge if you set the limits your self and you can cycle the batteries better it should not over charge or under charge the batteries, plus these clone chargers don't always charge nimh or nicads well.
I have made a couple of looms up using magnets as per your pictures for balance charging 18650 etc batteries which appears to be working fine. Do you use the same looms for charging NiMH aa aaa batteries in the NiMH setting part of the charger?
With your icharger set your Nimh sensitivity delta to 2mv/cell in the settings menue, now and then i form charge them its like nimh balancing, its in the icharger nimh menue and you can use the same holders from the above link.
You have to use the "min/max" function on you DMM and have it connected when you charge. If it records a maximum voltage of 4.2 volt, the charger is doing a good job.
Hobby chargers usual terminates at 1/10 charge current, i.e. if you charge at 1A it will terminate at 0.1A. If you wish to terminate at a lower current, you must charge at a lower current. This will make the battery voltage higher.
A LiIon battery is NOT supposed to be 4.200V, this is a myth. The charge voltage is supposed to be between 4.15 and 4.25 volt and will always leave the battery at a slightly lower voltage. This can also be seen in all my battery test/reviews, the voltage drops when I stop charging.
The PEAK-button of the UT61E is quite confusing and i dont know how it works. Might be similar to Min/Max-button of other DMM's, but i am at loss here.
Connect the DMM, start the charge, the you press the PEAK button once and the DMM will record both min and max values. Press PEAK again to change display between min and max.
If the charger has noise in the charge current, the PEAK function may record to high and low values.
The only ways to get 4.2 volt on the battery is to use a very low termination current or charge to more than 4.2 volt.
