IMAX B6 multi-battery type charger
Reviewer's Overall Rating: ★★★★★
Summary:
| Batteries supported to charge: |
Li-ion, Li-po, LiFePo4, Ni-Cd, Ni-Mh, Pb... |
| Input voltage range: | From 10v to 18v DC |
| Max number cells: |
Ni-Mh 15 cells - Li-ion 6 cells |
| Discharge function: |
Yes |
| Power supply: |
EXTERNAL (included) |
| Temperature monitoring: |
Yes |
| Price Payed: | 36,20 USD |
| Date Ordered: | Aug 2011 |
Pros:
- Charges almost all chemistries (the most common)
- Selectable charging/discharging current
- Maaany functions available (automatic discharge, storage condition, etc...)
- Includes the power supply and temp sensor
Cons:
- Does not charge Ni-Zn chemistry
- Discharging current a bit low (only 1000mA)
- External power supply a bit bulky
Summary:
| Max number cells: |
Yes |
| Power supply: |
Yes |
Pros:
Cons:
Features / Value: ★★★★★
I am pretty impressed for the amount of functions it has. In few words: it charges almost everything....
All chemistries except Ni-Zn..... It can charge:
- Li-ion
- Li-po
- LiFePo4
- Ni-Cd
- Ni-Mh
- Pb
(NOTE: Ni-Zn chemistry would be interesting, but AFAIK, no hobby charger has Ni-Zn support)
The box:
Incredible amount of functions... still dont know how to operate it completely...
UPDATE1:
Pb batteries are charged perfectly, my two 12volt 7Ah SLA´s are now ready to use in case of power outage or bad weather... etc. Even I tried to charge an old 44Ah car battery, but with no luck... showed error message in the screen after "checking battery". Maybe old battery.. who knows
Ni-Mh batteries, after playing with the "delta V", now they stop charging more precisely (I have noticed that it depends on the cells itself, not all the cells with work with the "default" setting. All is "test and error").
The temp sensor is a good idea specially when charging old Li based cells, you can select at wich temp it stops charging for avoiding a "vent with flame" issue.
Design / Build Quality: ★★★★★
Frontal and back views:
The sides:
Wires....
Temperature sensor and car battery adapter...
And the included power supply (a bit bulky):
Not much to say, good and robust finish with a blue paint and blue LCD backlight (no dead pixels in mine)... Good accesories as power supply and wiring (good gauge...)
Summary: ★★★★★
Despite I dont know exactly all the functions and despite the fact that I have not tested it with all the chemiestries it accepts, I think this a good one for charging the most common batteries we have around, specially designed for RC hobbists who use the car battery to charge the batteries on the field. Also usefull for flashaholics, good for knowing the real capacity of the batteries, and so on.....
The price, the included accesories(i.e. the power supply), and all the functions makes it a good choice without damaging your wallet too much......
VIDEO SHOWING FUNCTIONS
Remember that DX offers this charger from different wharehouses.... if you want it, choose the one corresponding where do you are from:
HK wharehouse http://www.dealextreme.com/p/imax-b6-2-5-lcd-rc-lipo-battery-balance-cha...
UK wharehouse http://www.dealextreme.com/p/imax-b6-2-5-lcd-rc-lipo-battery-balance-cha...
US wharehouse http://www.dealextreme.com/p/imax-b6-2-5-lcd-rc-lipo-battery-balance-cha...
