How tight is that black frame that the window sits on? In my mod I’m planning to ream the reflector so that it fits precisely around the frame. But it must not be sheared off the first time that I drop the light and the reflector applies sideways force on it.
Sounds good. It looks like an uncoated window so I would expect maybe 5% loss from it, so the gain is a bit higher than you would expect from just the window.
It is glued on fairly well. I used a Feather platinum coated blade and worked my way around the LED pad, slicing at the seal little by little and being careful not to power thru and cut the bond wires…or slice off a hunk of finger…the blades a super thin and sharp, just keep the blade on the LED pad just under the steel frame of the lens…
I placed a small smooth reflector on top of the bare led that made a decent hotspot on my ceiling. I measured the tint of the hotspot at 4 currents.
current
CCT
duv
CRI
0.1 A
5100 K
+0.0164
67
0.5 A
5140 K
+0.0152
67
2 A
5270 K
+0.0122
67
10 A
5620 K
+0.0061
67
The colour temperature is fairly neutral, at lower currents even significantly lower than Neal listed, and despite the high duv at lower currents I do not judge the tint as disturbingly green. The tint at 10 A looks quite perfect.
thank you. i sent an inquiry to lantend. i’d really like a couple of these to try out. my concern was the position of the tint bin which is depicted in the data sheet as well above the bbl.
Lantend charges you the shipping, DHL at $35. So unless you’re getting several of them the shipping makes the price point pretty high. And of course, China is shut down between Chinese New Year and the Corona Virus, it would be very surprising if you got any response before Feb 8th as the government has instructed businesses to stay closed until then. Getting a package out of China may take quite a while with all that’s going on over there…
