Looks awesome!
A 21700 version would be awesome!
Love the LT1, would definitely be in for at least 1 of these even if it’s 18650.
Will they have the same nice LED’s or start from scratch?
The plan is to use the same High-CRI LH351 series 2700K to 5000K LEDs as used in the full size LT1.
Nice :+1:
Did I say I’m in?
Well I’m in for two.
How much output are you considering?
Interested
Probably between 325 to 400 lumens on maximum, (testing is underway with heat and running the host using a 4000 mAh 21700 to determine average run times, heat lad, etc. While the IF25 specs stated an average of 300 to 325 lumens on mode Med#2, and 6.2 hours on the 4000mAh cell from the factory, (they stated 240 lumens on 2700K and 450 lumens on 6500K tint settings at the ramp-ends. Their high mode they claimed 660/1100 lumens for 2.8 hours @ 2700K/6500K (but that’s out the front as a flashlight. In this case as a diffused lantern that output will be lower. If we can achieve 350 lumens with a high mode/mixed tint around 4000K/and get to 5 hours run time average with Audruil firmware, that would be great for such a small version of the LT1.
As you know, I love the lt1s I have. and you may also know I wish it had a powerbank function. if it also had a flashlight function it would be exactly perfect.
Well now with this one, flashlight and powerbank function without being too long would make it perfect as well.
Really excited to see this!! Hope Sofirn goes with colors on this one too. Great going DBSAR!! You’ve created solid products that are making an impact.
Thank you for the support. :+1:
I have been designing, thinking, testing and working on the LT1M (mini) idea for some time, and videos coming soon, as with a new main topic for the LT1M to be posted soon. The same team of us who brought the BLF LT1 lantern to life will be doing it again for this smaller, more hiking-friendly version.
If it has a red light mode, I’m in.
I’m in, the teaser photo clinched it. Using the IF25 platform seems like a great idea.
I have the if25 and I really like the idea of a lantern based on that. If Anduril cannot be ported I think the stock UI ramping just needs some fine tuning. Reduce max output to something more sensible and add candlelight mode and that would be perfect mini LT1.
As a bonus those 3S aaa adapters fits and actually works nicely with the IF25 at lower modes. So an optional power source for emergencies and for those who are not comfortable with li ion batteries. I guess you just have to make sure nobody tries to charge aaas with the built in charging.
Interested in the 21700 version.
I really like the way the prototype is coming along. Exciting.
I wish anduril had a muggle mode that had full brightness.
I think there are some mistake here. Lantern for backpack can’t be simply scaled from large-size camping lantern, like LT1.
LT1, of course, is very featured product for specific use. We can easy use it for autocamping, or use on village summer-house. There are a lot of power in 4*18650, powerful throw up to 700 lumen. For large amount of people or large tent in such cases, we can place it on the large table or hang somewhere.
In this situation accucase works as stand for emitter, and a little place near it with low light not used. Moreover, plump accucase works as stable support on flat table.
But in case of backpack and hiking use such design, scaled to 1 21700 accu d’t seem so nice. There are not large companies, there are not large flat tables in large tent. Sometime it’s used for small tent, right on blanket for two-three peoples. So we d’t need so long (accucase+emitterglass) and so slim lantern. Because it would be instable on blanket. And we d’t need upper opaque reflector. Because very often it could be fixed head over heels.
And we d’t need 360 horizontal cover everytime. We, sometime would need only 180 degrees light on one side and on the end of lantern
So, i can assume, that the best variant would be a little thicker layout, where battery (21700) is inside case and emitter. With strong but little ground magnetic support.
As example of round we can look at Zanflare T1(which can change color temperature), and oval - like Nitecore LR50 (which can use different sides because of task).
T1 could be easily used on any position - on flat table, on metal screw, on hook in car, on blanket - very stable because of it’s size and proportions of length to width.
LR50 could be easy used by two or three persons with power economy - just disable unused side.
I think, that true little backpack lantern with low weight and sizes should be a combination of well used LEDs like Samsung LH351 of different color temperature, anduril interface and emitter built AROUND batterycase. And, of course, with ability to disable butt light and at least one side.
By this we would receive very stable lantern, which could stand up even on sleeping bag, work wonderfully head over heels, work for a long time because of economy on unused sides, have positive buoyance and be very nice backpack lantern.
The main question is, of course, how we can use energy-efficient leds like LH351 in such construction? May be, we can place them around inner battery case polished column on footing of lantern, pointed them to the upper end of lantern, some light would leave throw frosted glass and other mirrored from battery column.
Another question is heat dissipation. Of course, we would be limited by metal area of footing. But for backpack light high brightness is not very important, moreover, we could by throwing of light for unused side and power of LEDs easy use available dissipation possibility.As example, the average light flow would be arount 200lumens, but that could be 200 lumens on everyside (180 degrees on horizotal and upper end), and 200 lumens only from one 180 degrees side. I think this would be enough for hiking tent or small place of evening eating etc.
Of course, the path of just scaling LT1 is very easy, especially by using IF25 host. But i am truly sure, that real backpack lantern should have different layout.
Or we can simply use IF25 with diffuser. Voila.
