Are you sure that clip is non reversible? … it looks reversible to me.
Changing the battery with the clip reversed would be awkward though since it would scrape against the head unless you used your fingers to lift it slightly.
I didn’t test or calculate the distance, but my eyes saw it reaching at least 200m, as shown in some photos above. More than that, I am not completely able to say concrete data :zipper_mouth_face:
Well, it can be reversible, but it will a) open the clip and force it more, and b) scratch the head.
While with the tip towards the tail it has a “groove” that allows that clip curve to pass without scratching, towards the head it with have friction with the fins! And it will scratch the anodizing.
I should have explained better this before.
If comparing the clip inversion in this light and in the Olight S1R Baton and the On The Road M3 Pro, in these last lights the clip (that has similar shape) will fit much better and without friction with the host!
I didn’t test or calculate the distance, but my eyes saw it reaching at least 200m, as shown in some photos above. More than that, I am not completely able to say concrete data.
Which one has more range: Acebeam TK16 XPG3 or Imalent LD10?
I believe my answer will be a little like the above one, as I don’t have the LD10 to compare. If I had, I would do real comparisons, but I guess the best way to compare them without that is picking the specs:
TK16 3xOsram = 338m
Imalent LD10 = 247m
About taking the bezel out and reaching the lens / TIR / Leds? I just pressed the bezel against the hand or a glove and rotated the flashlight.
It was not glued. Once you have the bezel out, you’ll reach the rest easily.
If you are asking about the driver side, I didn’t dismantle it, but it has a screw that can be taken out eventually.
One day, the clip just broke apart and shot off the light. One of the arms on the clip that grips the light literally just snapped off. I wasn’t even carrying the light when this happened. It was sitting on a desk. The light was less than 3 months old at the time.
Apart from the crappy clip quality, it’s a great light.
