Hello,
Any reviews on this lantern? Is the battery replaceable? The colorful leds look nice.
Hello,
Usually a built in battery is difficult to remove. Most likely a sealed unit
Maybe this opens up?
Found it on amazon and reviews suggest it’s a poorly lit night light, nothing more
Sorry for my English.
The battery in the lamp cannot be removed, the bottom cover is glued. The lamp has PWM in most modes, it does not shine very brightly, but like a night light or evening light, it is quite acceptable. I did not succeed in disassembling the flashlight without breaking it, so while it is working normally, I left an attempt to get inside.
I was impressed with the changing colors. How does it have such a huge range of colors.
Obviously, color LEDs are used.
The light really looks very interesting, but unfortunately the brightness is regulated only in white light. Color LEDs always shine at maximum.
I bought Lantern a year ago at Gearbest. It works reliably. Changing colors is very easy. It is not sealed with glue. It is easily demountable. The battery can be replaced when it is connected to the connector. There are three small screws under the sticker. Other screws are at the bottom. Remove the bottom cover and remove the batteries. The circuit board is also fastened with screws. The battery connector is at the bottom of the PCB. Disassembly is complete in 5 minutes.
Very interesting. Thanks for this.
Just because yours wasn’t glued doesn’t mean that’s the case with all. There could be variations between all the different sellers
It is true. The only certainty is death. Perhaps my answer helped someone…
This would be a good lantern to go camping with young Asian girls .
I’ve been looking for another Zanflare T1 and also saw this last year. But the battery seemed weak. But it might be cool for my bro and his kids when he needs to wake up to check on the baby. Still not totally convinced on these those.
