Hi guys, a short update of the shipping status of the 2nd batch.
Yesterday I shipped the first half of the 2nd batch, just not yet sent the information via PM, cause of time troubles. I go in the order of payment.
Today I already prepared the shipping labels for the rest of the 2nd batch and will bring the to post tomorrow or monday.
I will also update the list in post #2 with the names of all interested.
I did not measure but I put mine on and it lasts at highest ramp for over a minute. Probably longer but that is good. I did not convert F to C in the beginning so I thought it was no better but once I set room temp and thermal limit correctly it is now as expected and I really like this light even more. Thanks man of light!
P.S. I used MX4 on sides of plate and everywhere as shown By man of light, and I have a copper head with Aluminum body. I did not have any tolerance issue getting my plate to slide into the copper head. I was generous with extra MX4 on the sides and so MX4 gets on the headās inner threads a little as you slide it in but thatās ok I just leave it there. this way I have a good thermal path to the the head. I read the MX4 works even better after several cycles on/off. Lining up the screws is really the hardest part and would be same for all minis. Put your screws into the plate first and itās easier to line up.
Thought you were only doing one batch? I finally installed mine. Works perfectly. After the drop down it sheds the heat rather quickly for another run at turbo
Yes, thatās what I thought. Since I have never organized something like this, I didnāt know what the effort is. When I realized how much work it was, I thought only the one batch, not more.
But after the first batch was delivered and I was asked whether I would do more, the effort seemed manageable and I decided to continue for the community.
Well, the FFE07 has no design flaw that can be corrected by a heatsink, like the MF01 mini / MT07.
Yes the E07 gets hot quickly, this is because the body volume is rather small in comparison, but the heat regulation works quite well on this and there is no bottleneck to solve.
The only way I can think of to thermally improve the E07, is to develop an alternative head design. Slightly longer (10mm), optimized cooling fins design and made of copper with way more mass. But then the modification would be quite complex, you would have to exchange all the head innards and the price would might be too high. Not sure if there is enough interest for such a thing.
I just have to say that Iāve had mine fixed with the heatsink for a couple of weeks now and I absolutely love it. This has become my favorite light. Mostly due to the fact that it can sustain the output for so much longer than any of my other high performance lights. This light was once the least best-performing light of mine and now it is definitely the best. Thanks again man of light.
:+1: This is true. I have several flashlight that outperform this one in output and time before thermal throttling, but this one is several times smaller and lighter. The mod made it my favorite flashlight and I carry it daily. Its really good and stable. The output is amazing for its size and the heat transfers much faster to the flashlight body now, I can even warm up my hands nicely now (brrrr winter)
I also use my modded MF01 mini now more often then my D4Sv2 or FFE07. I like the size and the beam profile of it. I ordered a full copper MT07 and look forward to modify it also, will do some comparison runs then.
