*The "Micro Lanterns" -What i built and modified!
39 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 6 days 20 hours ago
I know a few was waiting for this topic with the video about the many micro lanterns i built & modded, the video shows most of the details.
- These all range from 5 lumens up to 50 lumens, and all brighter than a candle, even the tinyest, wallet size, which has a run time of 20+ hours on a CR2032 coin.
- Also both the micro “Hurricane lantern” and micro camping lantern, (smaller than a C-battery) has run times of 20+ hours on, and have a fire-fly glow mode that will likely run for 4+ years on a CR2032.
Below is the innards of the simple “wallet lantern” with 20+ hours run time and brighter than a candle.
The video of the many micro lanterns below:
nydude
Last seen: 2 weeks 3 days ago
These are very cool. thanks for sharing.
Watermanchris
Well, if you’re building a LT1 micro, I’m in for a handful.
Can you send me a link to that 5mm wallet lantern? I’ve got some high CRI 5mm leds I want to swap into it.
DBSAR
DBSAR's picture
Its just a flat dual CR2032 battery holder, (the rest i modified & added, the LED, resistor, and rewired it for 2P set up.
its found here:
https://www.ebay.com/itm/5pcs-CR2032-6V-Button-Cell-Battery-Holder-Case-...
agent80
Last seen: 3 days 9 hours ago
Incredibly cool!
Watermanchris
its found here:
I ordered a 5 pack of those to build my own. What size resistor did you go with? I can’t see the full color code. Would you do anything differently?
dekozn
Last seen: 6 days 47 min ago
I’m wondering where u found that red mini hurricane lantern. That’s really cute.
Idiot proofing something only creates improved idiots.
DBSAR
DBSAR's picture
its a 22 ohm 1/8 watt resistor.
DBSAR
DBSAR's picture
it was a tiny pencil sharpener found at a local dollar store. Cool
iamlucky13
Last seen: 15 hours 57 min ago
I had been looking forward to your post about these. Thanks!
I need to find one of those pencil sharpeners, especially now that I’ve received my 2400K 5mm LED’s from rngwn.
It might be this. Is 3” tall about right?
https://www.amazon.com/TreasureGurus-LLC-Miniature-Camping-Sharpener/dp/B0779MNW12
It seems dollhouse and railroad miniatures are the terms to search for.
Was there a specific switch you used? I assume it’s a 3-position switch with one leg either direct drive or run through a small value resistor, and the other leg a high value resistor?
DBSAR
DBSAR's picture
i can’t get that link to work..
but this is the same one here: >> https://www.pencilthings.com/product-p/mei%20mx4028.htm
I used a single/dual on/off micro DIP switch. i used a 22 ohm , 1/8 watt resistor for the “on” mode, and used a 400K ( 400,000 ohm) 1/8 watt for the night glow mode that is wired direct to the battery holder.
iamlucky13
Thanks for the details! Also, the link should be fixed.
Parametrek
Parametrek's picture
Last seen: 3 weeks 2 days ago
Great video and some very nice mods. A few comments:
“We’re all familiar with the foxton”
You mean the fauxton. “faux” being french and pronounced “pho” and means fake. It is still pronounced pho-ton. Get the joke? Smile
I do agree with you on CR2032 being a nice little battery. It is my favorite for last-ditch lights.
Those remote phosphor LEDs look great! I’ve just looked through 2000 products on Aliexpress and Alibaba trying to find a supplier. Came up empty handed though. Tell us if you ever manage to find them.
I also really like the idea of the always-on firefly bypass resistor. I will have to add that to some of my lights.
Allow me to introduce you to my favorite little lantern: https://www.coghlans.com/products/led-micro-lantern-0842
It runs on 2xCR2032 and comes with a Nichia LED. It has possibly the most impressive diffuser I’ve seen on a lantern this size. Conical mirror combined with a reeded linear optic. Of course I replaced the LED with a 3200k yuji. The keychain junk was replaced with a lanyard. I make my lanyards a bit longer than yours – just long enough to slip over a door knob. The battery situation was trickier. What I ended up doing was replacing a CR2032 with a thin rare earth magnet. So now it is dimmer and I can stick it just about anywhere between the lanyard and the magnet.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
63 brands, 3100 models and still growing!
Also: USA li-ion database
MRsDNF
MRsDNF's picture
Last seen: 2 months 5 days ago
The king of lanterns. You have had hours of fun and amusement there and no doubt a little frustration at times. Love
Agro
Agro's picture
Last seen: 1 min 31 sec ago
You made me decide to buy 2 lights. Facepalm Beer
The NEBO and the smallest CR2032 ones. Though I fail to find a cheap source of the latter, FT seems the best, $3.51 for a 10-pack with the BLF coupon. I have a feeling they can be had for less…
Agro
Agro's picture
As to remote phosphor LEDs – I also failed to find any. Though I see that diffuse lenses are easy to get. I suppose they are not good enough?
DBSAR
DBSAR's picture
I have seen those in photos, but we never had them here in Canada to get my hands on one to modify. Big Smile
DBSAR
DBSAR's picture
Yes very much so for the frustration at times, but the quest to create the perfect tiny lantern has always been a goal. Big Smile
DBSAR
DBSAR's picture
I wish i knew who makes those remote-phosphor warm-white 5mm LEDs, as they are the most efficient, widest light-angle tiny low-power LEDs i ever seen. these seems to glow the brightest of any LED i ever tested for a white LED on a 300K+ or higher resistor. (other than the tiny straw-hat blue LEDs) So far its only in the Walmart $1 garden solar lights i have found them.
ecotack
ecotack's picture
Last seen: 5 days 4 hours ago
I had a search last night for the remote phosphor LEDs and couldn’t find any, but just did a quick google for 360 5mm LED and there are a few in the image search.
The other ones I thought may be good for a even light are the filament LED, like you get in retro bulbs. They are easy to find on eBay, aliexpress etc.
iamlucky13
Maybe sanding the dome on one of rngwn’s LED’s would result in a comparable light distribution? There would be a little bit of light loss, but it should diffuse it.
DBSAR
DBSAR's picture
ecotack wrote:
I had a search last night for the remote phosphor LEDs and couldn’t find any, but just did a quick google for “360 5mm LED
I have thought about trying those filament LEDs, they do seem like a good idea for small lanterns. I was always curious though of their efficiency vs. amp draw, as the filament LED used a couple dozen tiny separate LED diodes along a micro PCB strip, coated in a remote phosphor “tube” as such, versus a single remote-phosphor 5mm that uses a single LED diode in the center. Some of those 5mm LEDs in that 360 degree search does look close to the ones i have.
DBSAR
DBSAR's picture
yep, did that too Big Smile it does increase the light distribution, but it does create some light loss.
dekozn
That’s really cool man, I like it.
amishbill
amishbill's picture
Last seen: 2 years 2 months ago
Want one?
Or Two?
I’m sure Amazon or Walmart will ship to Snowlandia…
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
DBSAR
DBSAR's picture
amishbill wrote:
Want one?
Or Two?
i can;t find them on our amazon.ca site, or our wallyworld.ca site. Cool
Parametrek
They are at amazon.ca: https://www.amazon.ca/dp/B001AZHFGQ/
I’ve also bought unbranded clones but I can’t find them anymore on aliexpress/dx/banggood.
rngwn
rngwn's picture
Last seen: 2 days 10 hours ago
Just 2 cents, by sanding down the dome of LED, you might want to leave some slight arc to mitigate the output loss due to (total) internal reflection. (And that’s the reason why the wide angle LEDs are strawhat-shaped)
For regular LED epoxy, the refractive index should be about 1.5, which translates to ~41 deg of critical angle. That means the incident angle from the phospors to the furthest edge of the dome should not exceed that angle (or try to minimize the distance towards the edge where the critical angle would be exceeded), or the light will go backward due to the internal reflection.
DBSAR
DBSAR's picture
For some odd reason they won’t ship to my address.. Facepalm
derfyled
derfyled's picture
If you want, I can order it for you and ship it at your place.
D'AVerk
Last seen: 1 week 1 day ago
Hi. As i have seen, there are blue and red brothers to Thorfire KL02. Do you makes any mods in led & driver for them?
