Any chance Anduril could have an additional feature/shortcut where one could have the Voltage fudge factor configurable, just like the temp calibration and all other configurable features ?
I think it would be easier to have a light's voltage reading adjusted in case you've had a sloppy flash, or you just don't know what dropout your driver has, or simply tolerance between individual components.
Just measure a cell with a decent multi-meter, pop in the cell, go batt voltage chk without loading it and compare - If any difference, go to vff config and adjust, save and Bob's your uncle.
I understand how to calibrate the temperature sensor, and how to set max temperature. But what is supposed to happen when you are running in temperature regulation and then double click to go into to turbo?
I have a new EC01 that I just calibrated and set for a max temperature of 45C (15 clicks).
From a cold start, I ramp to max, then doubleclick to turbo. The light heats up to about 50C using my IR thermometer. The output does decrease and the temperature doesn’t get any higher. Regulation looks good.
Then I doubleclick, putting the light back in turbo. The temperature rapidly climbes to 60C at which point I turn it off as it’s getting too hot to hold.
Does doubleclick bypass the temperature regulation?
Thank you so much Toykeeper for the instructions. I thought I had bricked my Fireflies E07, but apparently I just got into programming mode by mistake after a few too many beers and messed it up. Your instructions got me straightened out! All Hail Toykeeper!
I prefer NarsilM myself. Config can’t be entered by mistake and you can entirely disable thermal step down for those who like manual control. I also don’t always like all the blinkies and strobes. It’s great on the LT1 Lantern but most lights it feels too much
You guys would probably like my version of Anduril then. I got rid of the blinkies on the 3 click menu - all it does it voltage readout, temp read out, and version num blink I up'ed the max temp to 90C as well.
I would like that along with a method to simply load a user interface customized to my preferences through a USB-C charging port that also functions as a data port.
No clue what’s on it. It’s currently on the list of license violations since they’re distributing the product without providing source code.
However, I just recently got a bit of info about it, suggesting that the OEM might be Sofirn… so hopefully I can contact them to get it resolved.
And in general, I think there needs to be a map to help people figure out what firmware ships on commercial lights. Will probably put up something about that soon, since it’s a common type of question.
im positive the ec01 is made by sofirn, the switch feels identical to my c8f… weird they would be violating your license like that, they should know better.
