1) plastic sheets of variable thinkness and patterns
2) yes, or adhesive inside, or non adhesive outside if there is something to hold it, whatever suits best each cases.
2) look at my beamshots in the previous page, some lower the CCT a bit, especially #10 but also #13 and #14, all of the others too it seems to me, but it’s very faint (even on top of an already diffused beam, so not tricked by the uniformisation of the tint)
7) #7 is a strong diffuser (like #1), good if the goal is a floody headlamp, and thin, so good to go behind the glass
Sizes are given in the 1st post. #1 (dcfix) is adhesive and also a strong diffuser, I just put some on a h600fw on which I replaced the lens (by a clear one because I didn’t find frosted lenses), adhesive was needed because there is no space inside even for the 0.2mm thickness of #7 (or #1), it had to be put outside.
My camera is acting up ,but here is a after and before. Didn’t think there was this big of a difference in tint, definitely on smoothing out the hotspot, but the pics tell the truth.
I also got a special package from Boaz, and while I have no beamshots, I am quite pleased with the results. I put the original dcfix on an old thrunite t10 I use for a bedside light and it evened out the tint shift and smoothed the hot spot into the spill. I used some #7 on the inside of a s2+ 2700k convoy to flood things even more. Good stuff indeed, I just need to work on my cutting skills (even with trace around sockets and all).
Thanks for a great product and quick shipping Sir, I need to find a place to use the sheet of#5 thrown in for good measure. ;0)
Got my film a few days ago and subsequently forgot to post beamshots……
My wife has a Cricut that we use for cutting vinyl and paper to do crafts and make shirts. Its basically a cheap consumer computer guided knife. It cuts perfect circles =D
Ive so far added DC-Fix #1 to my Acebeam H40 which did exactly what I wanted it to. It smoothed out and made the hotspot bigger.
I also ordered a sheet of regular Zircon minus green. That went in my green SST20 5K D4S (v1) and it made a HUGE difference in tint. Its a good bit rosy, I almost wish there was a less aggressive filter option but im just nitpicking.
Great stuff overall and Boaz was great to work with!
The T1 is relatively easy to open, there is some threadlock but not the hard stuff, I used pliers+rubber but considering how easy it came it would probably have come by hand. So you can put the diffuser inside if you want.
