When is new X4 release date for UK
Will you consider VC2, VC4 upgraded version with USB-C.
(Maybe even with USB power delivery to get 2x2A or 4x1A?)
PB2S with 2x Samsung 50E charges iPhone 11 Pro with 8.8v at 1A (according to the display). Tested with original iPhone USB-C to Lightning cable and Anker Powerline/PowerlineII USB-A to Lightning cables. Is this correct? Seems slow.
bring back the WK42!
ozone, no
alcohol, sometimes
wle
In HKJ’s review here of the Xtar VC8,
It mentions that sometimes, the VC8 will not properly charge NiMh batteries to fully-charged status, and sometimes, it overcharges the batteries.
(a 2000mAh NiMh gets charged to over 3000mAh, or sometimes just 600mAh).
What might be the possible problem for this and can it be fixed?
Also, the “grading” function for NiMh batteries is also affected (“grading” function will do a charge-discharge-charge cycle), however, the “charging” portion may sometimes not charge to “fully-charged” state, so the “discharged” capacity will be lower than actual. Another thing, is the third “charge” cycle seems to not charge to fully-charged state too.
Still have my WK42, good light
Would like to have D35, can you do something about it Xtar?
Yes, ozone is harmful to the human body, but if we can use it appropriately then it is good stuff to disinfection
As for the charger, are you looking forward to having a Ni-MH charger?
I heard they are working on updating the RC2 Moon, but not sure when it could done. lol
But nice suggestion indeed, I will let them know.
The new X4 still out of stock in the UK market now.
This is the official store on UK Amazon: https://amzn.to/33TF2cG
Once it’s back in stock, we will make an announcement
Why do you want to do that?
Generally speaking, yes you can. But the virus will not survive on the surface of the package for too long.
Yes, we are processing that. USB-C is being used in many devices, we need to catch it up
I’m not sure under what environment you did the test, but the temperature and remaining battery of the phone will affect the charging speed.
Maybe you can turn the low battery mode on and test it again.
LOL, tell me why do you like this torch so much?
How does the WK42 works now?
I will let them know that you guys like the WK42 and D35, see if we could bring them back!
Any explanation yet for the Xtar VC8 which, based on HKJ’s test, sometimes will not charge NiMh batteries to full (only charges partially then stops).
Also, the Xtar VC4S seems to do the same thing when using the “Grading” (capacity test) mode — for Li-Ion batteries, it will ” Charge (FULL) - Discharge - Charge (Full)“, but for NiMh batteries it will ”Charge (FULL) - Discharge - Charge (partial charge only)“. See review done by HKJ.
So after a “grading” test mode for NiMh batteries on the VC4S and VC8, the battery will only get partially charged after the testing is done.
what is the cut off voltage of vc8 for discharging li ion in grad. mode, i could not find it in the owners manual, thanks
Have any WK35’s still hanging around that need a good home?
I’ll buy them!!!
I own both the vc8 and vc4s and have the same faults charging nimh batteries. Have contacted Xtar for assistance but no reply unfortunately.
i have same issue with other chargers as well, however not with all cells, eneloops charge fine, tenergy will not charge fully, same thing with Duracell’s nimh, i have hitek x4 hobby charger, i tried different currents , but no difference, whether i charge single cell, or a pack in series, i have another no name 8 bay charger, same story, enelopps charge fine, others do not, when i got Duracell AAs they came with cheap; 4 bay wall charger , i was gonna throw it away, since i had “better” chargers, good thing i did not
