Convoy XHP35 Driver Analysis / Testing / Schematic
51 posts / 0 new
agnelucio
agnelucio's picture
Last seen: 7 hours 46 min ago
I've seen a few people mention this this driver, so I bought some, and upon review, not only do they work well, as advertised, they have excellent modding potential.
I've gone through the driver itself as well as data-sheets for the identifiable components, and have deduced the schematic and layout for this driver.
Component values were measured directly and/or approximated from rough calculations and expected values.
Convoy copied most of the MP3431's passives from the example circuit in it's data-sheet, for instance (which is fairly common practice).
Any values (mostly capacitors) approximated as above are marked with a '?' symbol.
Schematic and Board Layout:
Schematic
Board Layout
Testing (after modification):
I modified one somewhat to drive 6V LEDs, and got the following results:
Assessment
The MP3431 used in this driver has excellent efficiency for it's size, maintaining 95% for low and medium outputs through most of the battery capacity.
Low and medium modes fall to approx 91% right at the end of the battery charge (3V), but are still perfectly usable (20W out). Driver LVP cut-out occurs at this point anyway.
Maximum output level has an acceptable efficiency of 85% at 50W output, but output drops with battery voltage due to regulator issue mentioned below.
It should be noted that the above numbers are AFTER I had reduced the output voltage, swapped the shunt, bypassed the polarity protection FET, and removed the input current limit set resistor.
The results in this table are NOT the STOCK DRIVER, but should be representative of it's performance potential (subtract a few % from efficiency numbers to estimate values for stock driver).
I may test the driver as stock at some other time if there are more requests for it.
*nerdy section, just ignore this if not interested*
The current control loop uses the Op-Amp as a comparator between the filtered setpoint voltage and the current shunt voltage, with the output pulling the MP3431 FB pin to GND or 2.5V through a 100k resistor.
Some quick calculations suggest that this is less dependent on Op-Amp gain-bandwidth product than other designs I have seen.
Some switching drivers I have seen previously (eg the H2-C) have used the Op-Amp as an integrator, slowing the control loop and resulting in integral windup (the bright flash seen as you change modes).
I prefer this comparator method, as it seems more responsive (eg better strobe capability), doesn't flash on mode change, and performs just as well at low levels without noise (flickering).
*nerdy bit over*
The only significant flaw I noticed was the choice of regulator. It's 3.3V out, and so as the battery voltage falls below that (plus dropout), the supply to the MCU and Op-Amp drops similarly.
This is the cause of the dip in regulated output currents as the battery discharges, and since the test above, I have replaced mine with a 2.5VLDO which solves this problem.
Conclusion:
This driver is very promising; to my knowledge, it's the highest-power boost driver commercially available in a 22mm size.
With some careful soldering, this driver has lots of potential if you know how to modify it to suit your need. I hope my diagrams will help with that.
I anticipate this driver becoming increasingly popular as it's quality and potential is recognised, and I hope that this analysis will prove useful.
Thanks for reading!
Edited by: agnelucio on 04/20/2020 - 22:54
Barkuti
Barkuti's picture
Last seen: 1 hour 21 min ago
Thanks a lot  for this thorough modding review, very enlightening.
Could you please link some alternative 2.5 VLDO regulator, or at least say its name? Is it a direct replacement or some other nearby passive needs to be changed?
Good thing is that R2 is just aside the VLDO, as I would also mess with it to reduce the high cut-off. How much do you suggest setting the cut-off at? 2.7 V or even lower?
Thanks!  Will link this in the Convoy thread.
By the way, how hard do you think it can go driving 3S or 4S emitters? Guess a bit less than the current you got for 2S / 6V emitters, doesn't it?
Further by the way, what modifications did you make for the driver to handle 2S emitters? Is modification also needed for 3S emitters?
Tue, 04/21/2020 - 06:50; Tue, 04/21/2020 - 06:54
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
id30209
id30209's picture
Last seen: 16 min 31 sec ago
Thx for all the details.
Too bad there are more people that can only resolder stuff but not playing with these tiny components.
Like me LOOOL
Anyhow, would you take a look in how to bump current output @12V from 2.5A to some higher levels?
WTB Titanium 4sevens 2xAA tube
Yokiamy
Yokiamy's picture
Last seen: 53 min 11 sec ago
Wow, very interesting info
It has thermal stepdown, could you point out the NTC ?
It might be R3
Barkuti
Barkuti's picture
Yokiamy wrote:
It might be R3
It's the tiny R4 next to C4, look at the circuit diagram. Curious.
No idea what the VLDO is, too blurred or unclear markings (??V15E).
A 50% current bump for 3S or even 4S emitter configurations is surely obtainable.
But people, pay attention to the current input! I wonder how the usual flashlight switch will deal with this, 20+A… Facepalm
Yokiamy
Yokiamy's picture
I have the L21A with XHP35, and with a 40T cell I measure 9,5 A on Turbo at the tail with the clampmeter (approx 40W primary)
According Simon this driver delivers 2,3A 12V to the LED) that makes it 27,6 W secundary (P=U*I =27,6 W)
EasyB
Last seen: 2 hours 35 min ago
Thanks for the testing and impressive results!
So the driver is dissipating about 9W in your high mode. Is this too much, or how do you cool it?
Yokiamy
Yokiamy's picture
This driver has temperature regulation set fixed (through the NTC) set at 55 DegC. so it does not get very hot.
That’s why i was asking which one is the NTC Wink
Check out the L21A review at 1Lumen.com
https://1lumen.com/21700-reviews/convoy-l21a/
EasyB
Yes, it looks like the temp protection works well in stock configuration, but in the boosted configuration from the OP I wonder how much extra heat in the driver there is and if it’s manageable. Like, does the temp protection cause it to stop down immediately.
Yokiamy, your stock measurement suggests not very good efficiency, but your numbers are approximate (maybe the output current is actually higher, and the Vf is actually around 14V) so maybe the efficiency is actually a bit better.
agnelucio
agnelucio's picture
I'm glad people are finding this interesting/helpful.
Thank you all for your kind words.
To reply to questions so far:
Barkuti:
Quote:
Could you please link some alternative 2.5 VLDO regulator?
Any 2.5V SOT-23 size regulator would work, as long as it has the same pinout. I took one from an LD-25 driver I had spare, but there are plenty on Mouser/DigiKey/etc. No other passives required.
Whatever the specced min voltage is for your cells. It used to be 3V, but some manufacturers are going down to 2.7/2.8 nowadays.
The LVP is taken from after the regulator (no idea why), so calculating the required value of R2/R3 gets a bit weird. It might not even need changing, as it's dependent on regulator dropout.
I also don't know how the MCU will behave at 2.5V. It should be OK if LVP is adjusted, but I have since removed mine, so cannot easily test.
Input currents will remain limited to ~20A. You need to work out the input/output voltages, calculate duty cycle, and factor in efficiency.
See THIS Application Note by TI. You mostly need Page 6. At a complete guess, subtract 1-2W from my maximum for each volt out above 6V, But I'd strongly advise you to do the calculations.
Quote:
what modifications did you make for the driver to handle 2S/3S emitters?
Replace R16. I'm using a 220k, but you may need a different value for your emitter(s). You need a value which puts the MP3431 output voltage at half your emitter Vdrop range.
Check LED test graphs for Vdrop range of your LED up to your desired max current, use MP3431 datasheet equation to find R16. Do not change R17 or R9, you risk breaking the op-amp feedback loop.
HAHA not well. It won't be a switch for very long. You could increase the soft-start (C12) to reduce startup inrush-current, but that's not really solving the problem.
You'd need a FET switch for rear-clicky lights, or modify it to use a side switch. I'm an E-switch guy myself, so I don't have that problem... laughing
id30209:
Change sense resistor (R10) to lower value. Please note that XHP35 Vf = 14.2V at 2.5A. That = 35.5W out, which the 10A input current limit will curtail as the battery voltage falls below ~3.5V.
To do full modification, you need to do what I did for my test (requires good SMD soldering skills).
If you are driving an XHP35, there's not much point, as over 2.5A will kill it pretty quickly.
Yokiamy:
Quote:
It has thermal step down
Where does it say that? The MP3431 has internal over-temp shutdown as a last resort, but the MCU doesn't have any external components for it like with some BLF drivers.
It may be internal to the MCU, similar to Narsil/Anduril, but I have no way to check it.
Similar to the previous reply, the XHP35 requires 14.2V at 2.5A. That = 35.5W out, so your test gives 100*(1-((40-35.5)/40)) = 88.75% efficiency, which is expected.
EasyB:
Thank you!
It should be mentioned that at 10W loss, only ~3.5W is dissipated by the MP3431 itself (conduction/switching). The remaining ~6.5W is lost to parasitics in the input current path (PCB traces, inductor, vias, etc).
The inductor DCR is approx. 3mR (VERY rough measurement), giving ~1.2W loss, though I strongly suspect that it is beginning to saturate at 20A.
I will try to find a better inductor to use, and will try some serious modification of the PCB to improve current handling.
I am designing a custom boost driver for a different project, and this driver works well as a testing platform for different ideas.
The testing I did was with the driver in open air, so I kept high mode test runs to 5-10 seconds.
Mounting it properly in a flashlight body would solve that issue, but would make it much more difficult to test and modify the driver.
My future modifications should hopefully improve thermals. The 3.5W I can tolerate, the other 6.5W (that I can do something about) need to go wink.
Yokiamy
Yokiamy's picture
agnelucio wrote:
Yokiamy:
Where does it say that? The MP3431 has internal over-temp shutdown as a last resort, but the MCU doesn’t have any external components for it like with some BLF drivers.
Simon said it before in his thread where he announces all new products. It is noted as well on his product page HERE
Quote:
Driver instructions:(4modes)
modes : 1%-10%-40%-100% max current output is 2300mA
Its biggest advantage is that no frequency can be seen in any mode, and there is temperature management.
It can control the flashlight temperature not to exceed 55 degrees Celsius,
If the flashlight temperature is below 55 degrees Celsius, it will output full current. If it is above 55 degrees Celsius, it will constantly adjust the current so that the flashlight will not overheat.
Yokiamy
Yokiamy's picture
As stated before, Simon said it will do max 2,3A to the LED, which is according the sheet you are referring to approx 13,5 V
That makes it 2,3*13,5= 31 W, So 9 W dissipation and 31/40=77,5% efficiency
It sure looks like R3 might be the NTC, i will measure it when i have the time and when i fancy it
agnelucio
agnelucio's picture
Ah, interesting. Thanks for pointing that out, although that is for L21A light, not this specific driver.
The page for this driver by itself does not mention it…
If it is the same driver, it must be using MCU internal temperature sensor, or maybe one of the resistors is NTC.
What was your battery voltage when you measured 9.5A? How did you get the figure of 40W input?
Yokiamy
Yokiamy's picture
Freshly charged 40T, measured at the tail of the light with an UNI-T UT210E
The L21A uses exactly that driver
https://www.aliexpress.com/item/4000046041955.html?spm=a2g0s.9042311.0.0...
agnelucio
agnelucio's picture
The driver image you show above is a different driver. It appears to use LD-25 style FET constant current, though the MCU and op-amp setup look very similar.
Fair enough. Good to know. Big Smile
As for the 40W input, according to HJK , at 10A, the 40T drops almost immediately to ~3.9V due to internal resistance.
That *10A would give 39W input.
XHP35 is 14V at 2.3A = 32.2W
32.2/39 = ~83% efficiency. And that’s including losses in driver spring (if you have one), reverse protection FET, LED wires, etc.
I used Kelvin connections right at the driver for all my measurements, so my results will be slightly higher in efficiency.
Dlux
Last seen: 1 hour 2 min ago
Really interesting, thanks a lot for your effort! Beer
Barkuti
Barkuti's picture
Thanks, 2.5 - 2.6V li-ion cut-off for me. With proper modification (a higher than 6V max input voltage regulator, for example) this could work with 2S configurations, LiFePO4 batteries, etc. 2S cells is good for driving 4S or “12V” emitters at a higher power, with less current stress on the components.
Concerning the LVP R2/R3 divider thing, I'm confused. You say it takes voltage output from the regulator, this technically isn't very right imho and of course it means the MCU couldn't measure battery voltage this way. But it works, because once input voltage gets close to 3.3V, the VLDO's output starts decreasing. Presuming ≈0.1V of dropout (?), once input from the battery is just a hair above 3V, the MCU's pin 7 will be at 1.5V due to the 1:1 resistor divider. If the cut-off value at MCU's pin 7 is 1.5V, the LVP is then a bit above  3V. Do you know what is the actual LVP cut-off value at the MCU's pin 7, agnelucio?
agnelucio wrote:
Input currents will remain limited to ~20A. …
Mmmkay, but how is the input current limit removed or adjusted? I probably wouldn't mind trying up to 12/14 A or maybe a little more with some standard switches.
At half my emitter Vf range?  WTF?
Still didn't read the MP3431 datasheet, bear with me but, is adjusting really needed? I mean, I once measured no-load output voltage in one of my “6V” H1-A drivers and it went all the way up to ≈14.66V (datasheet says maximum output Question 12.6V).
agnelucio wrote:
… I'm an E-switch guy myself, so I don't have that problem... laughing
Is pin 2 from the VLDO a good place to set an e-switch?
Thanks.
MRsDNF
MRsDNF's picture
Last seen: 5 months 6 days ago
Love your work agnelucio. Thumbs Up Beer
icpart
Last seen: 6 hours 12 min ago
I prefer this comparator method, as it seems more responsive (eg better strobe capability), doesn’t flash on mode change, and performs just as well at low levels without noise (flickering).
nerdy bit over
You are not right in that case. The capacitor in anothers designs is for high frequency compensation. Without it the control loop of DC/DC converter can go unstable and oscillate depend on the load. It that and others Boost drivers OPAMP is like comparator i.e. it is Error Amplifier which compare reference voltage. So easiest method to adjust max output current in that driver is simple to adjust voltage divider R6/R7 without need to replace sense resistor. So if we have 3.3V LDO there is possible max amplitude of unfiltered PWM to be around 3.0-3.3V so maximum amplitude of Vref after filtering will be around 80-90mV. From 30mOhm sense resistor we can calculate that the maximum regulated output current is around 2.6-3A. For faster control loop I suppose they just used here faster opamp or without compensation which is bad in most cases.
Lightbringer
Lightbringer's picture
Last seen: 26 min 41 sec ago
Is the output purely current-driven, ie, is “100%” always 2.3A, regardless of the VF of the LED?
Interested in using these donks to drive some MT-G2s, but forgot if mine are 6V/3A or 9V/2A (and 2.3A is fine for me in either case).
If I don’t have to care about it, great.
icpart
No it is depend of it, If you put 6V LED the output will go over 12V and will burin it in matters in milisecond. The current loop is maybe no enough fast to limit output current to 2.3A without burn the LED. In that case you need just to adjust voltage divider at FB pin in which case is setpoint for unloaded output voltage of MP3431. In that case the MP3431 will go in constant voltage mode. So for 6V led is maybe better output voltage to be set at around 7-7.2V maybe.
agnelucio
agnelucio's picture
Thanks!
Ah cheers dude, I appreciate it Thumbs Up Smile .
You are right about how the LVP works. No confusion. I have removed the MCU, so cannot test it, but should be approx 1.5V.
Barkuti wrote:
Mmmkay but how is the input current limit removed or adjusted?
Adjusted - replace R14. See datasheet for required value. Removed - short R13 to ground.
Barkuti wrote:
At half my emitter Vf range? Still didn't read the MP3431 datasheet, bear with me but, is adjusting really needed?
Halfway between the min Vf and max Vf.   E.g XHP70 turns on at 5.3V and reaches 6.5V at 8A. Halfway is 5.9V, so set R16 for 5.9V out from MP3431.
The datasheet gives more info on the specifics. Not sure about the H1-A, but it's a different chip...
A switch to interrupt power to ONLY the MCU would work, so yeah, between LDO out and MCU pin1. You'd need to lift the leg of the MCU though.
Cutting power to the op-amp would make the light go crazy (most likely stuck in turbo or go into overvoltage shutdown).
icpart wrote:
You are not right in that case...
The integrator can have better standalone stability, but the DC/DC stage is compensated to be very stable for output voltage transients.
It uses FB to detect the output voltage, so the op-amp is just giving it lots of little adjustments, which are stabilised by the compensation network. Too much op-amp 'stability' = the MP3431 being slowed down.
You are right about the sense resistor/R6/R7, but it's easier for people to replace/solder a 1206 resistor than an 0402. And it can reduce output current power loss.
They just used it in a faster configuration. The op-amp does not need much compensating, as the MP3431 handles the power stage stability and responds very well to FB (see the bode plot in datasheet).
For my circuit, I tested the voltage gain required using LTSpice, but I will link an online equivalent HERE.
It can be seen that for eg an XHP35 needs output swing of ~11V to ~14V, setting the MP3431 to 12.5V. FB is regulated to 1.00V, so op amp needs to raise and lower FB so that 2.5V is divided into FB for an output swing of 11-14V.
Simulation shows that 1.05Vopamp = 11Vout, and 0.4Vopamp = 14Vout. So op-amp output swings 0.65V. 30mR Sense Vdrop at 2.5A = 0.075V. So op-amp gain required is 0.65/0.075 = 8.67.
That's very low in openloop, and gives the op-amp plenty of gain-bandwidth headroom.
Lightbringer wrote:
Is the output purely current-driven, ie, is "100%" always 2.3A, regardless of the V<sub>F</sub> of the LED?
For a given combination of PWM divider and sense resistor, yes. The only catch is that the Vf needs to be within the range set by R16.
Connected my test driver to a 6V MT-G2; it is happy to feed the poor thing up to 8A+. Lower currents no problem at all. R16 needs setting to 250/270k for the Vf though, so yeah, you need to replace one resistor (as icpart mentions).
SKV89
Last seen: 2 hours 2 min ago
Thanks for the data! Would be interested to see how the stock driver performs too but only if you have the time. I know these things take a lot of time.
Lightbringer
Kewl, tnx! I was worried about tranaients, as well as any “minimum output voltage” as far as stability.
Barkuti
Barkuti's picture
agnelucio wrote:
Low and medium modes fall to approx 91% right at the end of the battery charge (3V), but are still perfectly usable…
So there's no guarantee that the MCU will work below ≈3V. This alone sucks good. It would be useful to know how low can we go here.
Then, as the op-amp gets less voltage, it amplifies less, sense voltage reduces…  well, current output gets smaller. 91% is 3 / 3.3V, so I guess that if you switched to a 2.5V VLDO, you reduced your sense resistor value to 2.5 / 3.3 = 75.7̅5̅% to compensate for this, and/or did something else. Question
Barkuti
Barkuti's picture
Linking your above diagram here agnelucio:
Took a peek at the MP3431 datasheet.
I see shorting R14 or the nearby C13, or straight connecting ILIM to ground is what you meant to remove the current limit.
Page 21 from the manual describes how to set the output voltage, providing the equation R17 = (VREF / VOUT - VREF) × R16 (translated to your diagram here), where VREF = 1V = FB. So I see that the output voltage is set at 11V as it comes stock.
One more question which could be of interest to some, any potential problems making this driver work with 2S battery? It is within range of the boost converter. Only potential problem I see is with the VLDO, as the stock one probably has a 6V maximum input voltage limit. The rest is, well, for 2S input we need to correct the way the LVP gets its feedback, disconnecting R2 from the VLDO and connecting it to input. So: a) we do away with the stock R2; b) We install a new R2 of adequate value, 243KΩ would for example set the cut-off at 5.5V, but we set the new R2 like if we had rotated it 180° at its right side terminal, so R2 ends up disconnected from the VLDO and with its now left leg connected to the LVP pin and R3; and c) We lie a wire from VCC to the now free right side R2 terminal; as I see it we can take VCC from either side of R1.
icpart
From datasheet of MP3431 is better to calculate and adjust as Barkuti mention R17 not R16. From theory here http://www.ti.com/lit/an/slva662/slva662.pdf also R16 can affect loop stabilitty of MP3431. Yes you right that MP3431dc loop is very stable but here we have added second control loop with Opamp which can go unstable and oscillate in some cases so to prevent that it will better to add little compensation compared to without it. I also made simple Spice simulation of control loop of H1-C driver with XHP50.2 LED and OPA333
Here is compensated opamp with 1nF capacitor:
Here is with removed capacitor:
You can see how output can go to oscillate. Yes the behaviour of real circuit can be total different and to work stable for most of cases.
So if we have MP3431 set to 11V and from datasheet for typical XHP35 the output current will be around 200mA not at all in 2A region, very interesting . Also is better to sample VCC after R1 because we have RC filtering of pulsing VCC.
Yokiamy
Yokiamy's picture
IC Part, very interesting!
Unfortunately i cannot see the spice simulation
Barkuti
Barkuti's picture
icpart wrote:
… I also made simple Spice simulation of control loop of H1-C driver with XHP50.2 LED and OPA333
Do you mean H1-A, or H2-C?
https://lh3.googleusercontent.com/AaeCvtv_FqPCAqp…
https://lh3.googleusercontent.com/ffjnU1DmO7yuQX1…
Removed the images, they weren't working anyway. Left their links…
Are these links, or some sort of revenge? Weird, long, encoded URLs.
There may be people who understands what you say here; just not me. ¯\_(ツ)_/¯
icpart
Sorry for images. They are shared via Google photos and the links seems to be encrypted. I think they must be visible in threat anyway? You right H1-C with Tps61088 The simulation was from Tina Ti. Also I simulated that driver with MP3429 in PsPice and Opa333 with XHP35 LED PsPice model from Cree. MP3429 is exactly the same but without current limiting feature. It seems to work but without feedback compensation of OPamp it will go to oscillate in simulation. I will post waveform from that simulation later. So if you use higher bandwidth OPamp maybe will be better and stable but most of them have large input offset voltages. So that will be important if you need to control low output currents where the offset voltage really matter. Also so far best designed boost driver which I saw here is KX70 http://budgetlightforum.com/comment/1156736#comment-1156736
If you look more careful the circuit there is also used Type II opamp compensation with additional resistor and capacitor.
Barkuti
Barkuti's picture
By the way, the MCU used in this driver is, according to my sense-making knowledge, the same as is found in the newer generation ∅17/20/22mm SST-40 linear drivers. And according to good guy BMS, it is a Renesas RL78/G10 R5F10Y14/16 (datasheet). The unit with 2KB of Flash ROM must be used in drivers with Biscotti clone or Biscuit firmware. It works between 2 - 5.5V if limited to 5MHz max, and between 2.7 to 5.5V for higher frequencies (that if I've understood enough, see page 28 in the datasheet).
