Interested for 1!
Yes I hope.
interested
Interested
Yep, I am interested, depending on what the features are. Only problem is, I want it now!
Interested
Also interested in this
Interested!
TK, or I, can't do much without a driver. So the driver is the first thing we need developed, and we need a fairly good electronics designer for this.
Of course loneoceans with a lume1 variant would be great for this.
Need to have the switch on a right angle board. There is actually a little slot for the switch board in the body, at least as designed.
Factory driver.
https://imgur.com/lM312oD
INTERESTED!
There's some good news - Sofirn contacted me to order the stock SP10S to have as reference. I find this to be a step in the right direction, so hoping the ball will start rolling on this project! I also recently picked up a ThruNite T10T V2 on the special deal offered on Amazon, which is a similar AA light in that it takes any AA size battery, e-switch with a decent UI, similar design.
The UI of the T10T V2 is very similar to Anduril/Narsil:
From OFF:
- click ON to last used level
- click/hold to moon
- dbl click to turbo/max
From ON:
- click for OFF
- click/hold for cycling through levels (though it's only 2 levels to cycle thru -- wut were they think'n?)
- if at max, dbl click to strobe
I prefer the click/hold to switch brightness levels, and the 1 click to turn it OFF. This matches up so well with Anduril in non-ramping mode. The current SP10S uses click to cycle thru levels, click/hold to turn OFF, though the SP10S has more levels/modes.
Great news!
Staying tuned!
Interested
I’m interested!
thanks for the update
if the design is still open for suggestions,
I would prefer a tailswitch, so SF12 instead of SP10
And AA Tool Ti instead of T10T
imagine a titanium host with a tailswitch, running Anduril on an Eneloop… now THAT is an unmet need.
for those who dont yet know, Anduril has not been implemented in AA voltage…
while Im wishing, I want the UI to support a stable, regulated firefly output…
word is Anduril cant do sublumen without flicker… so it cant compete w V10r, V11r, D10, which not only Ramp on AA, they go way sub lumen… if Anduril is to compete for a full featured EDC, it needs to step it up with some sublumens on primaries…
I wasn’t aware of this. Where has it been discussed?
My FW3A certainly does sublumen without a flicker…
pleased to become better informed
link to light meter readings?
found one reference to flicker, suggests you are correct that anduril can do sublumen around 0.6 without flicker, and 0.2 with flicker:
